Tune Up (pugs & Wires)
I have a 2005 Sierra 5.3 with 79k miles. I was wondering when I should look to have new plugs and wires put on? Anything else outside of normal maint. that I should have done as well?
Sean
Plugs and wires good for at least 100k. Use AC delco when changing. Or NGK. You might check condition of belts, hoses and coolant. After 5 years I'd flush and put new Dex in it. Cheap insurance. Serviced the trans or diff(s) yet? You'll get plenty of other recommendations.....
I'd say the factory wires, which I believe are a high quality silicone insulated wire, are good for at least 200,000 miles. I had a 99 with 220,000 on it and the wires were still good when I sold it a couple months ago.
While the wires tend to last pretty well, the ends tend to show some signs of deterioration as the years roll by. I found that my ends were in pretty poor shape after 6 years so I replaced plugs (with the same AC plugs in it) and the wires at 100000 miles, oh and cap and rotor as well. The tune up was noticiable the first time I started it.
