Exclusive Clique?
It seems to me that one must have to be part of an "Exclusive Clique" on here to get any help or replies. I thought this would be the best place to inquire about fluids and capacities for my 01 HD because most of you seem to eat, sleep and dream GM. Apparently I was wrong or nobody knows the answer to my question(s), which I believe is highly unlikely. If its the screen name well that has no tie to the song...every name I came up with was taken or too close. Im an avid hunter and shooter so thats where the name kind of ties in. Im not whining or complaining...I'm bitching :( How many topics does there need to be on what kind of oil, synthetic or regular etc etc?. Everyone seems to jump on those bandwagons and beat them into the dirt but I can't even get an answer or even pointed in the right direction. For God sakes people just pick a quality oil and filter and keep it changed at regular intervals. Doesn't matter how good x brand oil works for Bob down the road...its how Bob drives and maintains his stuff. I know a guy who uses nothing but recycled oil and swears by it because he says that is what is used in many aircraft and his vehicles have close to 200,000 miles on them. Me, I wont use what he uses in a lawn mower. Is he right or wrong? Am I? Who knows. Oil and lubricants are just like anything else...everyone has their preference and reasons for such. As for those who have helped me, answered any posts that I have posted or pm'd me I just want to say Thank you :lol:
You should ask your question in the Heavy-Duty section. They know more about the common type axle in the 2500HD (14 bolt). The fluid is 75/90 and make sure there is no additive for a limited slip or it will mess up your G80.
Also number your questions out for us. Its hard to read long paragraphs.
Welcome to the forum!!! Hope you find the answers your looking for.
I agree how its hard to read long paragraphs.
The the topic starter:
I find that posting in the "Full-Size" section gets more replies than posting in this section.
Case in point I made a brake and rotors thread and got some replies and once it was moved to here, replies have dried up!
Also sometimes people just don't plain ol' answer! No point in getting bent out of shape on it, it definatly won't help your cause.
Yeah alot of people have thier 2 cents when it comes to brands/synthetics/conventional.
I have gained alot of knowledge on this site, and I'm sure you will too! Welcome! :(
I'm not part of any "exclusive clique". :cheers: But, I usually try to give my 2 cents when I feel like it, .............and the question kinda interests me. Lift kits and whatnot do not. Electronics do. Me, I use synthetic valvoline and a purolator filter. I don't jump on anybody about there preferences ........except when I see someone is using a FRAM!!!!!!
Yep, you must be a part of the very exclusive clique of owners that read deeper into the owner's manual...
Straight from the manual.
Fluid and Lubricant Recommendations
Usage
Fluid/Lubricant
Automatic Transfer Case
Automatic transfer case fluid AUTO-TRAK II Fluid (GM P/N 12378508)
Automatic Transfer Case (Diesel Engine)
Automatic transfer case fluid (GM P/N 12378396)
Transfer Case (Pickup)
Use Manual Transmission Fluid GM P/N 88861800 (Canadian P/N 88861801).
Automatic Transmission
DEXRON®-III, Automatic Transmission Fluid
Body Door Hinge Pins, Tailgate Hinge and Linkage, Folding Seat and Fuel Door Hinge
Multi-Purpose lubricant, Superlube® (GM P/N 12346241 or equivalent).
Chassis Lubrication
Chassis Lubricant (GM P/N 12377985 or equivalent) or lubricant meeting requirements of NLGI # 2 Category LB or GC-LB.
Engine Coolant
50/50 mixture of clean drinkable water and use only GM Goodwrench® DEX-COOL® or Havoline® DEX-COOL® coolant.
Engine Oil
Engine oil with the American Petroleum Institute Certified For Gasoline Engines STARBURST symbol of the proper viscosity. To determine the preferred viscosity for this vehicle's engine, refer to Explanation of Scheduled Services .
Engine Oil (Diesel Engine)
Engine oil with the letters CH-4 or CG-4 is best for this vehicle. The CH-4 or CG-4 designation may appear either alone, or in combination with other API designations, such as API CH-4/SJ, CG-4/SH or CH-4/CG-4/SJ. These letters show American Petroleum Institute (API) level of quality.
Floor Shift Linkage
Lubriplate® Lubricant Aerosol (GM P/N 12346293 or equivalent) or lubricant meeting requirements of NLGI # 2 Category LB or GC-LB.
Front Axle (S4WD)
SAE 80W-90 Axle Lubricant (GM P/N 89021671, Canadian P/N 10950849 or equivalent).
Front Axle (F4WD and all 9.25)
SAE 75W-90 Synthetic Axle Lubricant (GM P/N 12378261, Canadian P/N 10953455) or equivalent meeting GM Specification 9986115.
Front Axle Propshaft Spline or One-Piece Propshaft Spline (Two-Wheel Drive with Auto. Trans.)
Spline Lubricant, Special Lubricant (GM P/N 12345879) or lubricant meeting requirements of GM 9985830.
Hood Hinges
Multi-Purpose lubricant, Superlube® (GM Part No. 12346241 or equivalent).
Hood Latch Assembly, Secondary Latch, Pivots, Spring Anchor and Release Pawl
Lubriplate® Lubricant Aerosol (GM P/N 12346293 or equivalent) or lubricant meeting requirements of NLGI # 2, Category LB or GC-LB.
Hydraulic Brake System
Delco Supreme 11® Brake Fluid (GM P/N 12377967 or equivalent DOT-3 brake fluid).
Hydraulic Clutch System
Hydraulic Clutch Fluid (GM P/N 12345347 or equivalent DOT-3 brake fluid).
Key Lock Cylinders
Multi-Purpose Lubricant, Superlube® (GM P/N 12346241 or equivalent).
Manual Transfer Case
Manual Transmission (5-Speed with Low Gear, RPO MW3
GM Goodwrench Synthetic
Application
Specification
Metric
English
Axle Capacities
Front Drive Axle (8.25")
1.66 liters
1.75 quarts
Front Drive Axle (9.25")
1.73 liters
1.83 quarts
Rear Drive Axle (8.6")
2.28 liters
2.41 quarts
Rear Drive Axle (9.5")
2.6 liters
2.75 quarts
Rear Drive Axle (10.5")
2.6 liters
2.75 quarts
Rear Drive Axle (11.5")
3.62 liters
3.83 quarts
Engine Cooling System
  • 4.3 L (VIN W) Automatic Transmission
11.9 liters
12.6 quarts
  • 4.3 L (VIN W) Manual Transmission
12.2 liters
12.9 quarts
  • 4.8 L (VIN V) Automatic Transmission
12.7 liters
13.4 quarts
  • 4.8 L (VIN V) Manual Transmission
13.0 liters
13.7 quarts
  • 4.8 L (VIN V) Automatic with front A/C
13.7 liters
14.4 quarts
  • 4.8 L (VIN V) Automatic with front and rear A/C
15.0 liters
15.8 quarts
  • 5.3 L (VIN T) Automatic Transmission
12.7 liters
13.4 quarts
  • 5.3 L (VIN T) Automatic Transmission with optional Air Conditioning
14.1 liters
14.9 quarts
  • 5.3 L (VIN T) Automatic Transmission with front A/C
13.6 liters
14.4 quarts
  • 5.3 L (VIN T) Automatic Transmission with front and rear A/C
15.0 liters
15.8 quarts
  • 6.0 L (VIN U) Automatic Transmission
14.0 liters
14.8 quarts
  • 6.0 L (VIN U) Automatic Transmission with optional Engine Oil Cooler
13.6 liters
14.4 quarts
  • 6.0 L (VIN U) Suburban/Yukon-Automatic Transmission
15.0 liters
15.8 quarts
  • 6.0 L (VIN U) Suburban/Yukon-Automatic Transmission with optional Engine Oil Cooler
14.6 liters
15.4 quarts
  • 6.0 L (VIN U) Denali-Automatic Transmission
14.0 liters
14.8 quarts
  • 6.0 L (VIN U) Denali-Automatic Transmission with optional Engine Oil Cooler
14.6 liters
15.4 quarts
  • 6.0 L (VIN U) Manual Transmission
14.4 liters
15.2 quarts
  • 6.0 L (VIN U) Manual Transmission with optional Engine Oil Cooler
14.0 liters
14.8 quarts
  • 6.6 L (VIN 1) Automatic Transmission
19.2 liters
20.3 quarts
  • 6.6 L (VIN 1) Manual Transmission
19.6 liters
20.7 quarts
  • 8.1 L (VIN G) Automatic Transmission
19.6 liters
20.7 quarts
  • 8.1 L (VIN G) Manual Transmission
20.0 liters
21.1 quarts
Engine Crankcase
  • 4.3 L (VIN W) With Filter
4.3 liters
4.5 quarts
  • 4.8 L (VIN V) With Filter
5.7 liters
6.0 quarts
  • 5.3 L (VIN T) With Filter
5.7 liters
6.0 quarts
  • 6.0 L (VIN U) With Filter
5.7 liters
6.0 quarts
  • 6.6 L (VIN 1) With Filter
9.5 liters
10.0 quarts
  • 8.1 L (VIN G) With Filter
6.1 liters
6.5 quarts
Transmission
  • 4L60-E 4 Spd. HMD Auto (M30)
4.7 liters
5.0 quarts
  • 4L60-E 4 Spd. HMD Auto (M30) After Complete Overhaul
10.6 liters
11.2 quart
  • 4L60-E 4 Spd HM Auto (M32)
4.7 liters
5.0 quarts
  • 4L60-E 4 Spd HM Auto (M32) After Complete Overhaul
10.6 liters
11.2 quart
  • 4L80-E Auto (MT1)
7.3 liters
7.7 quarts
  • 4L80-E Auto (MT1) After Complete Overhaul
12.8 liters
13.5 quart
  • 5 Spd. Auto Allison (M74)
7.0 liters
7.4 quarts
  • 5 Spd. Auto Allison (M74) after complete overhaul
12.0 liters
12.7 quarts
  • New Venture Gear 3500 Manual Transmission
2.3 liters
2.4 quarts
  • New Venture Gear 4500 Manual Transmission
3.8 liters
4.0 quarts
  • 6 Spd Manual (ZF) (ML6)
6.0 liters
6.3 quarts
Fuel Tank
  • Short Bed Models
98.0 liters
26 gallons
  • Long Bed Models
128.0 liters
34.0 gallons
  • 4 Door Utility
98.4 liters
26.0 gallons
  • XL (1500 Series)
123.0 liters
32.5 gallons
  • XL (2500 Series)
147.6 liters
38.5 gallons
  • Chassis Cab (Single Tank)
128.0 liters
34.0 gallons
Fuel Tank-Federal
  • Chassis Cab (Standard Side Tank)
102.2 liters
27.0 gallons
  • Chassis Cab (Optional Rear Tank)
87.0 liters
23.0 gallons
Fuel Tank-California
9000.0 liters
24.0 gallons
  • Chassis Cab (Rear Tank)
87.0 liters
23.0 gallons
102.2 liters
27.0 gallons
Fuel Tank-Diesel
102.2 liters
27.0 gallons
87.0 liters
23.0 gallons
  • Power Steering Capacities (approximate)
0.77L-1.25 liters
0.81-1.32 quarts
Owners manual can be your friend.
or your worst enemy :cheers:
Thanks for the welcome. Sorry if I got a lil bent out of shape. I was going to post in the "Heavy Duty" section but I have read threads on there that people have said should have been moved or posted on this section so that is what I did. Maybe I should have posted them there. I was in need of info ASAP and was hoping to get it here...which I eventually did. Sorry if I offended anyone...just hard sometimes to get good help these days.
