New Member From Pa
Cierra05
Hello,
New member from Pittsburgh, PA here. I have owned several GM and Chevy trucks as listed below. Currently have a 2011 GMC Sierra 1500, Z71. Pic attached, I have not done anything to it yet. Mods to come soon.
GM trucks owned:
1978 GMC Jimmy
1988 Chevy 2500
2003 Chevy S10
2005 GMC Sierra
2011 GMC Sierra
Welcome. I love pittsubrgh. Lived there for just over 8 years.
Congrats on the new truck! What mods do you have planned?
Welcome fellow Pa'er,I'm just South of you down here in Greene Co.
Plan on a Black Bear custom tune in the Spring for one of your mods....Best $250 bucks you can spend!!!
Planning the following mods come spring.
New grill not sure which one yet.
dual pipes
chrome brush guard
K&N cold air intake other than that motor is staying stock
chrome door handles and tail gate handle
tint front windows to match back windows
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
