Installing An Auto Dim Mirror In A 2011
I am going to pick up a 2011 silverado tomorrow and will be missing the auto dim mirrors from my '08. The '08 has the DL3 mirrors, and I know it is not really possible to install them on a truck with DL8. I can live without them.
I would like to install the auto dim ISRV mirror though. I know I can get the GM rear view camera kit and will in turn get the auto dim mirror, but $900+ is just ridiculous when the option only costs $450.
Would it be possible to use the ISRV from a LTZ with navigation, since that mirror won't have the RVC display, but still has the auto dim feature?
Thanks for the link Ryan.
I would like to install a mirror that does not have the compass/temp display since it is already displayed on the DIC.
What I need to know is if the 16 pin connector is retained on all types of mirrors.
I also need a P/N for a mirror from a "10/'11 LTZ with navigation. I am pretty sure that will give me what I need.
15816792
Just an update. Purchased the 15816792 mirror and it was just as simple as unplugging removing the manual dim mirror and plugging in the auto dim mirror and mounting.
Now why GM didn't just make this the standard isrv mirror is beyond me. Now if I could get the DL3 mirrors my '08 had...
I noticed you cant add a DL3 mirror to the SLE, they want you to buy the SLT dont they :confused:
Yeah I guess that was their strategy.
$$$$$ Thats why. It saves them a couple bucks on the truck, and retards like me will buy a more expensive option package to get them and other overpriced "fluff" features. :confused:
Man I need to do this, I miss the Auto Dim. I need to take a look at our new truck and see what wires are there.
If I could get the temp and compass to that would make the wife all so happy. She hates she cant see the temp when sitting to the right.
I will have to fiqure out what its wired for now, I want the most I can get for plug and play!
I believe you can get the DL3 on an SLE, at least here in Canada, with the SLE Exterior Package:
"SLE Exterior Package – includes remote vehicle starter system, fog lights, universal home remote,
power remote control exterior rear-view mirrors (heated, power folding with integral turn signal
indicators) and auto-dimming interior rear-view mirror. Also includes 17" Sport aluminum wheels"
It doesn't say in that description, but I'm pretty sure they're body-coloured, as well.
In the us you can't get the dl3 on an lt/sle but they can be added
I found one way around that for you GMC guys.....Order the All-Terrain pkg. ("GAT") in SLE trim and you get the DL3's as part of the package.
Then you get that broken SUV style dash :confused:
Then you get that broken SUV style dash :thumbs:
Yep,You do.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
