Afm And Oil Consumption
Please understand that my above comments were just thoughts about what might be happening causing the high oil consumption.
The problem is that most don't do it. If it were predictable, and based on wear, etc., GM themselves would have seen it long before production. There has to be some variable involved... something that makes some do it, while most don't.
Toyota has a "fly in the ointment", so to speak, with the 5.7L ($4k Air Induction Pump). If you read the threads and articles, you'd think the 5.7 was a ticking $$ bomb. Most Tundra owners don't have the problem, but if you do... man-oh-man. The difference, to me, is that Toyota is not taking care of their customers like you'd expect, where GM seems to be trying. At least oil consumption doesn't leave anyone stranded on the side of the road.
  • Replies 188
Update to 2007 Chevrolet Suburban
Service writer called today and said the Cylinder number 1 rod was showing wear. Not sure if tech who replaced pistons and rings forgot to button something up or low oil caused wear over time. They called GM and they are replacing motor. Should get Suburban back tomorrow morning. I asked if all updates had been done to the new motor including the shroud around the oil pan pressure relief valve. They said yes. My concern is what happens in another ~60,000 miles.
Also a note to anyone. Just a thought, when the Active Fuel Management engages, it sends pressurized oil to the lifters that collapse to keep the valves from opening and closing. It looks as if the pressure that builds up as those particular cylinders are compressed would cause air to leak past the rings into the oil pan area pressurizing the oil pan. As the piston is driven back down on the power stroke or intake stroke, the cylinder could become a vacuum sucking air and oil past the rings into the combustion chamber. As wear increases, so does the amount of air/oil leaking past the rings. It looks to me as if you would want to keep the intake valve open on both the power and intake strokes compensating with the computer for the mass air flow rate. Turn off the spark and fuel to the deactivated cylinders when AFM is activated. Then on both compression strokes you would want to allow the exhaust valve to open to allow air to escape the cylinder in order to reduce any drag on the engine. The biggest problem I see is that when AFM is activated with the exhaust valve open during the compression and exhaust stroke it would cause the exhaust to lean out with the added extra air being pumped into the exhaust manifolds which would make closed loop fuel control difficult.
In my opinion, the best thing would be to scrap the ideal. I didn't buy my suburban to get 20 mpg anyway.
mdavidthomas
Matthews, NC
Only issue I have with that is if your PCV valve is working correctly it should not form pressure/vacuum to that extent.
What kind of warranty are they giving you on the new motor? Is there going to be a specific warranty for the motor, or will it just be covered by the existing powertrain warranty?
2007 GMT900....I took mine in for an "oil consumption test" a month or so ago after it started burning oil around 40k miles....before that it burned 0 per oil change and I change at about 10%-15% on the DIC (6k-7k miles).
The "add oil" came on today so I took it back in as was instructed. I was told 2qts/3k miles was deemed normal...at which point I said, "if you advertised that you'd never sell a truck".
I was expecting that they'd come back with my usage being deemed normal. Surprisingly, they came back with abnormal. Parts are being ordered up to fix.
I understand that the PCV would work for the crankcase but I don't believe it would affect the pressure inside the cylinder if it is closed by the intake and exhaust valve. One other note, my vehicle had a lifter tick from day one and the car made a vibration sound (growl) when it deactivated the AFM. The new engine that I got back today seems extremely quiet when activating and deactivating the AFM.
Also, I work for a pneumatic cylinder company. If take a brand new air cylinder and plug port on one end of the cylinder it's almost impossible to pull the rod out or push the rod in by hand unless the piston seals allow air to leak from one side of the piston to the other.
mdavidthomas
Matthews, NC
I'm having no help from the dealer either. Started an oil consumption test, drove 3k miles or so, lost 2q of oil and they are telling me that's normal. It's really such a shame because these are great trucks otherwise. Can't wait untill my warranty is up so I can tune it and get rid of the joke that is AFM altogether.
If anyone on the lot was told that according to GM 2 quarts of oil for every 3k miles is normal, they would never sell another vehicle. I think just knowing that's how ignorant they are makes me want to stay away in the future. Then I remember that all the major brands have their major issues and it's a moot point.
I would think that 1 quart per 3k miles oil consumption would be right at the upper limit of "normalcy" for most vehicles.
About ten years ago Volkswagen played this game with customers when they complained about excessive oil consumption in their VW Beetle 2.0 liter engines. It was in 2 to 3 quarts per 3k miles or more range. It was only after many complaints and threats of lawsuits that VW admitted that there was an issue. It turns out that on many cars the oil control piston rings were installed upside down.
This forced the company to repair many engines under warranty. But of course they at first tried to find an easy way out and do nothing.
Well of course, what would you expect from JokesWagon/Audi. They always play games.
mdavidthomas
Matthews, NC
Sorry I must have mis-read your post. I was thinking you meant within the crank case.
The gas that is trapped in the combustion chamber is supposed to act like a spring and push the piston back down the cylinder during the intake stroke. So in theory it looses no pressure just compresses the spent exhaust gases instead of expelling them on the exhaust stroke.
So in your pneumatic cylinder you would pull the air in then plug both valves keeping the air inside. Which will then compress and expand what air was trapped.
It sounds good in theory but I would think it would cause pre-mature ring wear, which would answer the oil consumption concern.
Stopped by the dealer to check on my truck and was told new lifters are ordered for the drivers side. He also said they would clean the carbon from the rings.
try to have them change all the deactivation lifters - we had a truck in the shop that had just one stuck closed so we replaced it - a week later another stuck and we were in the motor again!
(hillbilly4uPosted Yesterday, 11:35 PM)
Went in yesterday for the second 1k consumption check. Has burned 1 qt. in 2 thousand miles. They handed me a paper from GM saying 1 qt. per 3k is acceptable and that I seem to be just a little over that. Don't think they're gonna do much right now unless it gets worse. I bought the truck from a Dodge dealer and the sales rep swore it was not AFM motor. Course thats his word against mine.
Which paper did they give you? The one I have is #01-06-01-011F that states 1qt per 2000 miles. You can look at the RPO codes in the glove box and figure out if it has AFM. There's also a place to enter your VIN and it will tell everything the truck was built with, but I can't remember off hand where that's at.
Yeah, thats the same one. Its a year old. Jan 09. I ran the VIN Decoder from this site for the RPO's. I have the AFM with iron block.
Guys...the only real fix is pistons and rings.
All the other stuff is a band-aid
Great to see a dealer tech chime in. I'm listening. The question is, do you guys do many, of the few that have these problems? IE change pistons and rings? Or won't GM let you unless consumption is over the little paper they give ya? I see Life is Great with a 4.8 LOL. That should tell some kinda story.
I wouldn't say a thing about the consumption if its not slowly damaging other stuff like cats and 02 sensors. There has to be more techs lurking on this subject. Please let us know what you think?
    • I have ordered the car link adapter and registered for the google dev, will need to finish verification process later this evening when I get ahold of our kiddos android tablet. I will be using windows vs mac so hopefully it goes smoothly. I have zero tech background but I feel I can manage this with your write up.    Do you think it will be different for me? My truck is a 2023 GMC 1500, I have looked heavily into the AI boxes but I consistently find common complaints with lag.    Does carplay auto open now that you have it set up when you get in truck and turn it on? Or do you have to do open the app everytime?
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
