What Lift Is This?
Just wondering if anyone has any input as to what lift is on this truck or at least what size and tire combo. Is it 6" with 35's? It does not look like it has a body lift to me....
Thoughts?
it's going to be just about impossible to tell the brand of lift without seeing the front lift components. the wheels/tires look like 20s on 35's more than 18s on 33s IMO. lift looks to be some type of 6".
ok, here is the front. Jimmyboy, what is your set up?
that truck has the 6" fabtech, which is really more like a 7-8" kit.
i have a 6" superlift with a .5" leveling kit. 20" XD Spys on 35" Toyo MT's
sweet looking truck, what kind of bumper is that? that is a half ton truck right?
yes it's a Vortec Max which has: 6.0L motor, 4L70 trans with "heavy duty" cooler, 14 bolt rear, rear disc brakes, and 4.10 gears (on most)
Chad, all of the photos came from the Buckstop Bumper website (Buckstop.biz). I am going to order the rear one for mine closer to the spring.
James, Did you re-gear going to 35's? I am thinking of lifting my truck and like the look of this, I was hoping to go with 33" tall tires because I was worried about re-gearing. I have a 4.8L with 3:10 gears (I think), will going to 35's turn it into a real dog?
3.10 isn't a gm ratio in the pickups, 3.23's perhaps. i didn't need to re-gear my truck because of the 6.0 , 4L70, and 4.10 gears stock. However you will DEFINITELY want/NEED to re-gear your truck.
I know this is another topic and not to sound dumb, but I am when it comes to the gearing thing. How do I find out what transmission and rear gearing I have in my truck?
your trans is the 4L60E your gearing RPO is in the glovebox and should begin with GT or GU followed by a number. take that code and put it into yahoo or google or bing search with gm gear ratio code and BOOM there it be!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
