5.3 To A 6.0
Look for value, if you find comparable LQ4 and LQ9 and the LQ9 is another $800, you could make the LQ4 better for that $800. The difference is flat top pistons for more compression and 91 octane tuning, betting the tuning is half the 20hp stock difference, maybe more.
Truth.
If i had the time, space, and money to build an LQ4 at the time, i would have. I didnt so i went with the LQ9
  • Replies 65
Lol... Well, 2 outta 3 ain't bad.
I've got plenty of time. Got to rebuild the rear end and trans first!
  • 5 months later...
So, I found myself needing an engine last week.
With what was presented to me as options by my go to mechanic and the countless $7k longblocks, I opted for the ATK HP93.
It's replacing a 5.3 that lost compression on #7 at 169,820 miles, Comp Lsr 265 cam, longtubes, 4.11s and a Circle D 3200 stall.
The motor swap was started late Thursday. I'm hoping to have it back by Tuesday. I'm replacing the sensors as well, all of them.
  • 2 years later...
Since ATK has been mentioned several times I figured I'd throw this out there...
I'm debating between pulling the LM7 5.3 out of my 06 Z71 Suburban and rebuilding it or building a mild LM7 on the side and swapping it in.
Downtime is a concern.
I'm looking at this short block from ATK and building it myself with a decent cam, 799 or 243 heads etc...
I'm looking for more low to mid range power (I've got a 6000# travel trailer) but retaining enough to run 80-ish on the Interstate unloaded.
http://www.high-performance-engines.com/product-p/sp75.htm
Sent from my moto g(6) using Tapatalk
  • 1 year later...
On 1/6/2011 at 9:06 PM, oldschool327 said:
I miss Carolina already. :troll:
The 4L60 can handle the power if built correctly, and yes you can get a computer from the yard but must be VIN coded with Tech2 and programmed, but now you are talking $$$$$ of additional money than just a simple swap of an engine.
This is NOT as easy as it seams gents.
This is why you pay extra for Justin to re flash a computer from another truck and it must be in the correct VIN range.
Trade the truck for a factory equiped 6.0 or 6.2 and youll be much happier with a drive train that was meant to handle it. You could always go the forced air route but still that is mucho $$ and tranny upgrades also.
Can y’all give e a lil info. I’d greatly appreciate it. Tryin to help and ole timer I look after , his 2013 gmc 1500 giving him a fit. Keep fouling plugs on cylinder 1 and 7: can I pull pistions out bottom end?
Don't know but popping the heads is much easier.
