5.3 Liter Water Pump Gasket Leak?
I am trying to determine the source of my coolant leak. At first I thought it was the water pump, but the weep hole is dry. It drips on the passenger side of the motor at the front of the oil pan near the AC compressor. The problem is I cannot see where it starts. I am guessing it is the gasket but i just cannot see it. My truck has 92k on it so a water pump leak would not surprise me. Any insight would be appreciated.
They leak from the gaskets all the time. Only seen 2 that actually leaked out the weep hole. I always put a newpump on anyways. Just for warrenty...
Had the same problem on my 2004 at something around 87k. Was the gaskets. Never saw any water, just saw the coolant level drop. Did find some orange residue where it had been dripping onto the motor out of the gaskets.
Only way I can think of to get quick confirmation is to remove the WP bolts one at a time. One or two of mine were seriously caked with nasty shit where it had been leaking.
Thanks for the information. I have read a few post stating the gasket leaks are common. Looks like I will have to pull the pump to find the source. At 92k I think I will replace the the water pump rather than just the gaskets or I will be doing it all over again in a few thousand miles. It does not look like too bad of a job and I will get to play with my air tools. I researched the pump and new ones range from about $120 (AZone), $140 (Napa), and $250 from the dealer (ouch!!). I think I will skip the dealer on this one. Probably will do the TS as well since it has to come off anyway, and they are pretty cheap. It would have been nice if this had been leaking 6mos ago when I did hoses and belts.
I am experiencing the same problem with a very slow loss of coolant with just a drop on the skid plate if the truck sits for a few days. I would check Pep Boys out, they have a Bosch water pump and gasket for $117.99 with a lifetime warranty. If not Amazon has an OEM AC Delco for $107.99, but I have never ordered parts from them.
I had the water pump gaskets replaced under warranty after about a year of owning my truck. Now, 7 years later, they're leaking again a little. I'll probably do it my self when I get time.
Mine had the same leak that your describing but at only 50k miles. I replaced the gaskets and haven't had a drop since. It's actually a very easy replacement.
    d.lowrey
    d.lowrey
  • Who's Online   3 Members, 0 Anonymous, 1,253 Guests (See full list)
    • Fix one problem and find another.   Truck didn't have a thermostat in it so I flushed out the system today and refilled with 50/50 Dexcool. This truck is so old (LOL) that it has a sticker under the hood alerting people to the fact that it contains such. There is also an orange supplement with the owner's manual alerting the owner that "Your vehicle is one of a number of late production 1995 General Motors vehicles that use a newly developed engine coolant in the cooling system..."   I was still a little flummoxed by what seemed like a rich condition (exhaust smell, and a puff of carbon with a punchy rev). While watching the coolant temperature and testing the thermostat with my scanner, I happened to notice the IAT (incoming air temperature) to the intake was -40F. I know the temp is below average today, but I can still feel my face, and I was wearing shorts.   D'oh!! I realized I had never plugged the IAT back in, and the airbox was out while I was doing coolant. So I paused, reinstalled the airbox and plugged in the IAT, and viola. Things cleared right up, and I watched the coolant temp climb to a reported 198 degrees on the scanner (195 thermostat) and then it dropped to 194 (open) and then back up to 198 and held. Let it cool, came back, checked the coolant level and was satisifed.   Victory lap?   It needed more than the couple of gallons of gas I put in it from almost bone dry, so I ran it up to the gas station. It had earned it, or, at least I was pretty certain I wouldn't be draining or removing the tank anytime soon.   CEL popped on just as I was cruising a nice steady 40mph, just after coasting down a slight downhill curve.. Of course, it did, because, why let me enjoy not having dash emojis for a little while.   I just happened to have the scanner plugged in. I don't text and drive but I might scan and drive. Don't tell the police.   P0401, EGR flow insufficient.    Well, hello, EGR... ...my old friend! Welcome to the party, now that the engine reaches the factory-programmed operating temperature. I'm sure it was gagging on hostile, rich exhaust and carbon this whole time so I'll take it off and look again.   At least it's easily accessible, and worst case, about $65 to replace.   To keep, or to sell... Hmm. I want it running correctly either way. It's easier to sell when there are no fault codes.   It needs tires (they're aged out and cracking)   It could probably use an oil pan seal, or maybe the timing cover gasket/ junction with the pan needs redone because I've got an issue there that leaves a drop of oil on the floor.   If I do tires I'm sure they'll say the ball joints could use freshening, and, and, and, and.... At some point I'll have to stop. I can't (shouldn't) make it perfect, that's not what this rig is.
    • Take it back. That's about all you can do.  Mark
    • Gloss black would look better, but I'd paint match the grill before ditching the chrome bumpers.
    • Mine has done that since new. The colder the worse.
    • Yeah, that's my understanding. The newer trucks are 433Mhz vs the older 315Mhz TPMS. Putting these wheels on is costing me a small fortune, but so far, I'm still OK with it.    Next week the chrome bumpers are scheduled to be replaced with flat black ones. That would complete what the dealer still owes me.
