Hd's With 265 Tires
05 1500HD
I was wondering if some of you that have a 1500hd or 2500hd run 265/75/16? If you have any pics, post them up so I can see the difference between the stock 245s, 265s, and 285s. I've found pics of 285s but not sure I want to step up two sizes b/c of mpg. Can anyone help me out and post pics? Thanks
265's prevented my truck from shifting into high gear until above 55mph. With the stock 245 size it shifts correctly. I have the 8.1/allison combination. I noticed a significant difference in towing performance. If you tow stick with the 245's. I choose to let the transmission choose which gear it wants to be in. If you are driving around one gear lower all the time it will negatively impact your MPG.
Mine has 265's with no modifications to the suspension.post-34515-1294976371_thumb.jpg I had the ECU programmed towith the new tire size for correct shifting as well as correct speedometer reading. I only get the slightest rubbing when backing up in a hard left turn, and only then if I accelerate too quick...
285/75r16
285/75r16
Did your gas mileage change much? What are you getting now with your 265's? Your truck looks nice.
I have 265 75 16s on my 3/4 ton and have no problems whatsoever. I average right around 14 mpg. The dealer put the tires on when I bought it and it is a Chevy dealer so I assumed they would put the stock size on, but when I got it they had put on 265s. Has anyone with the stock 245 size on their 3/4 tons seen better mileage than 14 with the 6.0 and 4L80E?
When I had 245's I got at best 15 but with my 265's the best i've seen was 16.
