Air Deflector
You must be a bit of a wuss if you can't get yours off, while a 66-year old had no problem. Want Gramps to come over and do it for you?
Just didn't want to break it, old timer.
I crawled under it and saw that it's hooked on in several places. It's off now, in one piece.
  • Replies 50
I feel you man. They always say "It just pops right off". There are like 20 clips I don't think it's going to pop right off. Did you use a flathead to get the clips apart?
For anyone who actually gives a crap about taking this off without risk of damaging it (or the bumper). Turn the wheels all the way to the right to access the two 10mm bolts on each end. Remove them, then start with the clip next to the bolt (use a small flathead to gently pry where needed). Remove it from that one clip then do the same to the other side. Go back and forth between sides, working your way to the center. Took me less than 5 minutes to get it off without any damage to either piece. "Just rip/pull it off" is NOT the way to do things when you're messing with a $40k truck.
does this piece have a purpose? or is it being taken off for looks?
Larry
Larry
it makes the truck more aerodynamic by forcing the air down.. by taking it off you increase the drag on your truck thus making it get worse gas milage.. probably nothing noticable. This is what i was told by a friend that was a mechanic. But i doubt any one in these forums is too worried about gas milage lol
Larry
Did tests on mine with and without the air dam and got exactly the same mileage. It looks better with it off.
Thanks for that. I figured out about turning the wheels when I was trying to remove the screw with 1/2" of clearance. Was not working. Was about 10 degrees so my brain was not functioning fully. I also figured I'd wait til it was warmer so the plastic is less prone to cracking.
maybe not on a $40k truck, but on my $43k truck it worked just fine :)
but then again, I've taken apart GM trucks to bare frames, motors to bodies, so I'm pretty well versed with how Gm puts things together.
if pulling that air damn off worried you, you'll never be able to pull the radio trim off of that SLT dash :M16:
I took mine off last weekend and it popped off pretty easy. Looks much better IMO and I've already had a few people ask if I did something more or added more lift because it makes it look even taller.
haha. I wasn't worried about pulling the air dam off, I was curious to see what kind of clips were holding it in place and when i climbed under to remove the bolts I figured it'd be just as easy to pull it off from the underside rather than ripping it off from the front. All I did was pull it from a different angle.
Most of the time air dams are used to create a low pressure pocket behind the radiator forcing air to fill the low pressure from the front of the radiator using that to cool the truck at higher speeds.
Larry
Remove the two screws (one at either end) and press the air deflector out from the backside. You don't have to pry the clips apart.
Or you could drive through deep snow and have it rip off the front of your truck like what happened to mine. :smash:
x2 I did the same thing..
Stumps and tree limbs work if you dont live in a snowy area.
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
