New 2011 Gmc Sierra
Well I've had my new 2011 GMC Sierra crew cab SLT 4X4 5 days now and I think its great.
I have had Chev, Ford & Toyota trucks but this one seems a lot nicer (I know I'm biased).
Also new to this forum, don't think I'm as popular at the old Toyota forum any more
oh well life goes on.
Only thing that have made me raise my eyebrows so far:
- the dealer told me he would have it trailer ready for me, the service dept. forgot to hook up the
12 trailer charging wire, the brake controller wire and pop in the fuse.
- Had a hood deflector installed complete with a nice scratch in it so after a trip back and haft a day wasted
I was off with my truck in good shape.
- I discovered when you shut off the ignition on GMC the trailer charging system stays hot, great until you
kill the trailer and truck battery. So off to the auto parts store and bought a continuance duty solenoid
and wired that up now the basic truck is done and I can start thinking about mods.
SWEET! nice to have you here...... the issues you have had is just the dealer. Tell them to shove it and find a new one :lol::lol:
welcome.. throw up some pics!
I will once we get a nice day up here... still snowing.
Welcome from TN! What Toyota did you have before?
2007 Tacoma TRD double cab.
mine didnt come withe the 12v wire hooked up either. not really a big deal. and the battery wont die. it has some battery saver deal in it. it shuts the power off to every where else and leaves you enough power to start.
The battery will die if you leave the trailer hooked up. The trailer wire is always hot.
It does not come hooked up from the factory. The wire to hook to a post is at the under hood fuse panel. One for 12 v to trailer one for 12 at the brake controller if not integrated. You need two nuts of different sizes for the posts. Kinda makes a pita if you don't know your bolt sizes :driving:
no it wont. the truck will shut all power off when the trailer draws enough to make the battery low but will leave enough power to start the truck. it will not die!!
