Hey everyone, I`m sort of new to the forum (used to be on here a few years back). Anyway I just purchased a 2011 Silverado, 4WD Ext Cab 5.3 Flex with towing package. I previously owned a 97 Z71 Shortbed and a 99 Z71 Ext Cab which was unfortunately totaled about a month ago.
This is my first brand new one and have been told after 1000 miles or so to change all fluids, oil, trans fluid, both diff`s...What are ya`lls thoughts about this and I`m sure theres a thread on here somewhere but what do you suggest as far as motor oil?
I personally changed the oil to synthetics and rear end fluid after the 1st 1000 miles. I've done this on all new trucks I've ever owned and neither have let me down.
Congrats on the new truck! Follow GM's maintenance schedule in the owners manual and you will have no problems. However, if you are on the anal side of maintenance like most here you will do the changes long before they are really needed. I agree with what Steven said above and did the same to mine. The front and rear diff do break in and leach metal wear particles more in the break in period. I changed mine F@R @ 3K miles. Oil @ 1200 to Mobil 1 Syn T@SUV 5W-30. I would not worry about the TC or Trans fluid until the 25K mile mark. That is what I am doing to mine. At 17K now.
As you mentioned, I just felt like I needed to change those two fluids to remove any possible metal flakes from the break-in process. After that, I've always followed the recommend maintenance schedules. :P
Thanks for the advice guys, I think I'm going to go ahead and do both diffs plus change the motor oil. I see now that 2011 and new the oil must be Dexos approved, I was planning on running mobil 1 full synthetic so I will have to look into whether or not it is approved.
Molbil 1 is not magical, heck in some applications it is nothing more than really expensive and mediocre.
I would not even consider changing the front diff fluid till you actually use it, I think you guys get a little snow periodically, maybe plan the front diff change for the second or third engine oil change to give it a chance to actually break in first.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
    • Same here, first I bought a few filters to get me going right after I bought my truck to do some short distance initial oil changes, then realized I could buy a case lot for less as they drop the price if filters or trans oil etc is bought by the un opened case lot as well as the discount for buying the vehicle there. So I have filters for a while but its good to know going forward, knowing to expect it to be a different part number and looking filter at the dealer and not be confused over it and think they are handing me the wrong part.
    • Saw Inglewood was in the National New last night for hail. Allot of hail. front end loader level hail. 😱
