454 To 350 Swap
I just got a 92 1 ton 4x4 with the nv4500 trans. It has the 7.4 in it but I don't need that much engine and that bad of gas mileage. I have a freshly built 350, it is an older 2 piece main but with lo5 heads. The 350 has been decked, has been bored .030 over, and a cam with .480 lift 288 duration. I know I will need a new chip to actually get the engine to run a tbi setup, but I have a few questions before I get that far.
1. Will the harness work.
2. I have a computer out of a 92 Z71 that was power everything with a 700r4. Will that computer run my 350 after I get it programmed?
3. I know I will need the accessories bracket off a 350, but the power steering pump is the hydro boost brake set up, will that fit the 350 brackets?
4. Will most the sensor hook ups be the same for both engines or should I just put all the 454 sensors on the 350?
The 350 will give me the power I want and decent enough gas mileage, but if I can get my cruise to work, not have a check engine light, and pass emissions, I will be very happy. Any suggestions will be appreciated.
