Block Heaters
Hey does anyone know the part number for a block heater fitting a 2001 1500 z71 W/5.3 L, i found the thread in the advanced tech, but that appeared to be for an 05 ish number, help is appreciated, and even if somone has done a write up on this i would love to see that
Why not call a dealer or a parts store for the number?
I did use the search and only seemed to find the part number for the newer trucks, unless its the same across the years, then i got it, and as far as the parts store, i trust you guys way more than autozone
Check with NAPA. You have a 5.3? If so the part should be the same as the 2005 for a thread in type
NAPAONLINE.COM Search engine heater after plugging in you truck info
GM part # 17800530
