Oxygen Sensor Brands
One of my O2 sensors went out and I see Advanced Auto carries NGK, Denso and Bosch. All sensors are listed at the same price. Has anyone had bad luck with a certain brand or should all of these be about the same?
Ive used Bosch before and never had a problem with them. I think your best bet though is to get ACDelco.
Second the AC Delco choice, which was probably the OEM part. The OEM part is required to be warrantied for 100,000 miles, therefore manufacturing specifications are tighter.
Get AC Delco OEM ones. I tried Bosch and they set off lean codes.
OE parts are all but mandatory when it comes to sensors and electrical bits in my opinion. Too many bad experiences with 3rd party stuff.
Yeah not worried about increasing horsepower, just want sensors that will work correctly and last for a while. The computer actually said that Denso was the OEM sensor. I didn't have the chance today to get under the truck to see if i could see a brand written on them.
Same here....never had a problem with them!
I would stick with AC Delco or Denso. I have heard about and experienced bad results with Bosch ignition parts and sensors on GM vehicles.
The OEM sensors on my Yukon were Denso when I pulled off the pre-cat units last year. I replaced them with Bosch exact fit which I bought on Amazon for half the cost of the Advance Auto price. No codes or issues. Bosch is an OEM sensor supplier for nearly every European manufacturer.
