Is your GMT-900 using oil
1,555 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Well I figured I was imune, but I'm not LOL. My wife's 2008 Tahoe with 130K miles had no oil showing on the dipstick!! It was 1.5 quart low at 30% OLM. I read the first 100 posts of this thread and then skipped to,the end. Was there ever a discussion of cause? Do the inactivated cylinders suck in oil due to closed valves (high vacuum) and then the rings carbo up and then don't seal well? That's the only thing I can think of. Or is there some other mechanism leading. To,the oil consumption?
If I install the Range, will the engine clean up on its own?
You woulda been better served to read the last 100 posts, or go back and read them all, in order to learn about all the associated problems and what to do. AFM is a flawed system built with cheap parts and indifferent tolerances. Most important thing is to turn off AFM via a Range V8 module or PCM tune, and make sure you have the revised GM parts installed as per the TSB posted on here. An oil catch can may help as well. Then If you are running synthetic oil, consider running conventional or semi-synthetic, and/or a heavier viscosity. Clean your piston rings and spark plugs as described on this topic. And check your oil at every fill up. Edited by Maverick Z71
There's a lot of theories floating around out there, but the bottom line is, GM tried to save a buck and screwed up! Any engine builder that built an engine like this would be out of business.
TOTALLY UNACCEPTABLE.
I just learned from my last oil analysis that my cam bearings and cam are wearing out at an alarming pace. Been seeing lots of valve train issues on these engines from '07 on up. Broken valve springs, wiped out lobes, stuck AFM lifters, & prematurely worn out bearings.
A fine job they did for us being loyal customers. :mad:
Edited by Jsdirt
Thanks. I'll go back and read the ones I missed. I only run dinosaur oil in the wife's Tahoe.
just changed the oil. I will get an analysis in a couple thousand miles.
I also have a 2008 Silverado w/ 5.3. It only has 22K miles. Looks like I'll be buying two Ranges and checking the oil much more often.
Edited by need-for-speed
Sadly, the folks who spent $50 GRAND on a new one won't know until it's just out of warranty.
The issue with dino oil in these engines is, if left unchanged for too many miles, will be more likely to plug up the screen under the pressure sender with crap that will make the gauge read very low - it'll get your blood pressure up there when you see it, and throw a light (P0521).
Edited by Jsdirt
The AFM shield deflects and helps stop oil mist/vaporization which has a greater chance of getting sucked out by the pcv system.
Will the oil catch can do the same thing? Possibly even better?
The shield was a band-aid by GM to try and save their asses. Few people reported it working, and those that did were back in the same boat just a year or so later.
Just enough to get you out of warranty ...
I've had a catch can on mine for a couple years now. Still burns oil if I use cruise control while towing, and let it scream to 5 grand on hills. If I go easy on it, the consumption is tolerable. That to me screams piston rings, no matter what GM tells me.
Thanks again for the replies. For my 2008 Silverado- it's still under GMPP extended warranty. Do y'all know if they will install the oil pan and valve cover mods without the oil consumption test? Or would it have to fail the test first?
I took my Sierra in for something unrelated and the dealer asked if I had the time to wait around to have the heads replaced (I did not, but I made time for that!)
Thanks.
Hmmmm, haven't seen anything yet on head replacement, although I must admit, I've only read about 40% of this thread so far. I've seen references to, rings and pistons, driver side valve cover and oil pan. Did they say why they replaced the heads?
The heads aren't the major problem (cheap valve springs are, but that's a discussion for another day) - I believe the problem lies in cheap and/or poorly designed AFM lifters, cheap/poorly designed piston rings and/or sub-par quality control.
My suspicion is they're running their tooling until the last possible minute to extract the most for their money. So, when the tooling wears out, you'll have thousands of engines that are out of spec, or on the ragged edge of being out of spec, and will become oil burners much sooner than they should. They change the tooling, and all is well for thousands of units until it wears out again. This explains the hit or miss nature of these problems.
Edited by Jsdirt
1200 miles. Checked oil this am and it was just a little under the full mark. Oil pressure still strong. Looks like its working. My wife is taking it to MN this weekend to bring my grandson back to his mama. Its about 600 miles round trip. I'll check it when she gets back and let you know what it says.
Well the oil was down about a 1/3 of a quart after this trip. Drove to Fargo this past weekend and checked it. Its was more than a quart low. So apparently the 5W40 slows the oil loss up to about 2000 miles then its back to normal loss levels (quart every 500 to 700 miles) Mileage is now about 104K. I think I'll change it at 3000 miles but this time I'll try conventional 15W 40 oil and see what happens. Anybody know if this is not a good idea? Too thick?
If it were me, I'd run 20W-50 if I were using that much oil.
The way I see it, the engine is pretty much junk anyway. Not going to hurt much running a heavier oil. I saw a big decline in piston and ring wear metals in my oil analysis by switching from 5w-30 to 10w-30. Even though the "10" is rating it's cold flow properties, it's an overall higher viscosity oil, which helped alot in my case.
I just wish I had started doing this right out of the gate
Thanks.
come to think of it, it was probably the valve covers. That little occurrence was maybe 5 years ago, so my memory is a little fuzzy.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,228 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
