Gibson Supertruck Exhaust
Hi every-one I was looking at the Gibson web site still trying to decide what system to go with, the Supertruck system looks good but my only concern is that because it is so close to the cab would you get a lot of noise through the cab vents on the back of the cab??  Also if any-one has this system how do you like the sound and performance upgrades??  Thank-you
I've never heard Gibson exhaust or therefore felt any power increases due to the new exhaust system.....Does it sound mild, mellow, throaty???...have you discovered any low-end torque or top end???? faster revs?? :)
Beware with the supertruck exhaust or any that exit in front of the tire. Ford used to do this on their trucks and the exhaust is bad for the rear tire rim and brake system. The heat/moisture from the exhaust can sometimes cause premature brake wear and the rear rim clearcoat finish can be stripped.
It is considerably louder exiting right behind the cab and be aware that if you are parked for a long time with the truck running the exhaust fumes will come into  the cab. I did all the research on this, because I was going to go  with a supertruck look and exit in front of the tire. But the facts listed above change my mind.
Up to you though.
