Any 870 Super Mag Owners?
jro909
Well i dug out my shotgun out for a little skeet shooting today and found that my barrel can only withstand up to 3 inch...yet its advertised as being able to shoot all 3 sizes..wtf i have no idea if this was a fluke or a money gimmick
well its chambered for all 3 sizes but the barrel is only stamped 2 inch and 3 inch..not the third..
I shoot 3.5" out of my super mag all day during duck season. Did you buy the gun used or something? You can swap the barrel out I belive to accomidate the 3.5", but I might be wrong about that.
I have two barrels for mine. The one that came with it shoots up to 3.5 inch and I also got a slug barrel for it. The slug barrel only shoots up to 3 inch. Did you buy the gun new or used? Sounds like maybe someone switched barrels on you.
i personally dont get the super mag... what benefit does the 3.5 have over the 3? the ammo just costs more i have a normal 870 express
standard 870 express. i can only shoot 2 3/4 and 3
actually, the standard express shoots 2 3/4"
the "magnum" shoots 2 3/4 or 3"
the "Super Magnum" shoots 2 3/4, 3" or 3 1/2"
I have a 870 Super Magnum Express.
id have to look. bass pro said it did either. i only ever shoot 2 3/4 anyways
the gun was new..on display out of the box...i'm not 100% if its a super mag now that i think about it... the receiver is stamped with "express magnum" the barrel that came with it is stamped for 2 and 3 inch shells...came with a rem choke(i think improved modified)
the shell holds more pellets
more powder also
I got the 870 super magnum with 26 inch barrel it says on the reciever SUPER MAG
But if you look at the barrel it says 2 3/4" and 3"
Directly underneath it says *3 1/2' with SUPER MAG reciever only*
My targets mostly include clay pigeons and tree stumps, and sometimes beer bottles.
The magnum loads are for fun and sore shoulders, my friends get a kick out of it when I mix a 3 1/2" in with the 2 3/4 trap loads!!
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 463 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
