Leveling Keys
Im thinking of buying a rough country leveling kit. If i purchased just the leveling keys and not the whole package would the truck still look good? If anyone has any experience or opion thanks for any help
i did a tuff country leveling kit in the front and all it is installing bigger torsion keys. i dont see a problem if the keys are for lifting it and not just stock keys.
very few people understand how keys work.
Let me make this simple for you.... if you can get the height you want out of the stock keys, then re-indexed keys are a complete waste of money. Try cranking your stock ones first, you might save some money
hi i used my factory keys and turned them 6 full turns each which raised the truck 1 3/4" to 1 7/8" which left the truck with just a slight rake and when i went to get it aligned he said it was still in spec but on the upper end. he brought it back to the middle and all was good . i installed 265 75 16 tires to fill up the wheel wells some more and got the look i was after .truck is 08 3/4 hd
Thanks for the input my stock keys were already cranked up to the max but i need a little more clearance to fit my 305s. i went ahead and orderd the keys i just didnt want the truck to sitting up too high in the front if i didnt order the rear blocks
