Let Me Know If You Guys Do This..
So I brought my truck to the local GM dealer to have the oil change (Brought my own oil of course) as I don't change it myself in winter (no heated garage).
Anyways I checked the oil level yesterday and noticed I was low, so I go to fill it up and had a hell of a time taking off the oil fill cap. When I finally managed to get it off, I noticed that there was blue lock tite all around the thread and o-ring of the cap, as well as the neck to scew it back in...
I've never seen this before and I used to change oil and replaced tires as a job! :thumbs:
I've seen it more than once, saw it on my 2007 GMC Sierra, and also on my 2010 Silverado. The sierra had it on the top of the neck on the filler cap, and on the neck piece that went into the valve cover, but the silverado only has it on the neck piece going into the valve cover...why is beyond me other than possibly the o-ring is poor quality and they wanted to make sure it wasn't causing a vacum leak?....doesn't make alot of sense to me, but hey...i don't build engines for a living so what do i know...
Never seen that done before, but that sure seems assanine. Especially with a plastic cap, I would give them a call and see what they have to say just out of curiosity
Yeah, Ill give them a call tomorrow and post what their reply is... :D
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 330 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
