2011 2-way Advanced Remote Start
WHY WOULD YOU GO THROUGH THE TROUBLE OF HAVING 2 PHONES WHEN DEI'S SYSTEM WORKS WITH BLACKBERRY?????
Viper Smartstart
The love of sub par OEM Starters on this site has me baffled... Yeah I wanted one at first but when it came down to it DEI is so much better
Viper Smartstart
The onstar app is much more involved, I was checking it out today on a iPod touch, it seems to be the best way to go.
I almost seems like I am better off just buying an iPhone and using the app I guess, better range, might be a little crazy to buy a second fone just for the truck though
my 07 has remote start, and i have an iphone, what app are you referring too?! could i possibly be able to use the app for my truck?!
Nope, Trucks from 07-09 have the "Obsolete" Generation 8 OnStar Hardware, so we are Completely, Totally, and Utterly SOL on the OnStar MyLink App.
Viper Smartstart
I have the app and it's not impressive enough to warrant 2 phones.... Last time I checked my truck comes with a fuel gage, TPMS, and odometer standard and the aftermarket unit works for lock/unlock and remote start.
If it didn't involve an onstar subscription and adding other hardware as well as a dedicated phone to make it work it would be a good option, Otherwise it seems like more work than necessary when the aftermarket has a solution right there.
yup but as my other post said, if you can live with physically going into your truck to check the tire pressures, odometer, and fuel level, DEI's got you covered on the rest
  • 1 month later...
I have the Remote Installed on my 08' Crew cab, its big, and i have to replace the battery about every 6-8 months, the range is a lot better than the original. When a tire is low, it will flash the appropriate tire on the remote screen with the psi reading and beep a few times. When low on fuel it will flash the fuel gauge at you and beep a few times. While in remote start, it will show a 10min count down, and it will beep when at 15 seconds to let you know that its about to turn off, if you wanted to do the second remote start. It has a back lit screen that will operate at night. When you have the radio playing, you can use the remote to change the stations or track on the CD. It also has a mode to control another GM vehicle and will also remote start it if applicable.
  • 3 years later...
Curious if you may be able to help me out? I have a 2011 Sierra and want the better 2 way advanced remote start. Of course nobody knows anything because GM dealers simply look up thing s by VIN number and usually don't know about anything that doesn't show in their search results. My truck already has the required hardware installed (AP8 - REMOTE VEHICLE STARTER PREP PKG) but I need to find the correct version of the advanced remote start to purchase. From what I've seen above I just need to order the 2010 version, I just don't want to spend the money and have it not work. I have a shop that says they can install it, they're not a dealership because I figured the dealers wouldn't install 2010 stuff into a 2011.
Can you offer any assistance? I'd really appreciate it!
Your dealer has to be able to help you, since you have the ap8 rpo code i know it can be done. I had my dealership install and didnt have an issue. Thats all the unformation i can provide but it can be done.
Personally, it wasnt worth the money. At first its cool but after a while the big key fob is just to big. the screen scratches easy too. So if you get one but a screen protector on it as soon as you can.
I had it in my 2010 GMC Sierra , mine didn't come with it installed, I bought it and took it to the dealer to install it.. If they are telling you it won't work, then they are full is it and just giving you the run around because they don't want to install it.. My dealer told me the same thing, it won't work, and if we do get it to work then it probably won't. Work correctly.. Five hours later I had my Sierra back and everything worked right... It takes a while for the dealer to install because they have to go through a process of checking boxes for the new features of the 2way remote.. It takes time and they don't want to do it or don't like doing it..
  • 3 weeks later...
It seems like none of the dealers know really anything about them and their only setup for VIN specific accessories. Since I want the 2010 Advanced remote in my 2011 nobody can answer any questions and there are two possible part numbers for mine that include the RPO code AP8. Nobody can tell me which one I should use according to my trucks other RPO codes. I don't want to flip a coin and lose money on the system and install. Looks like I will have to keep searching.
http://www.gmpartsgiant.com/oem/2010-gmc-sierra-remote-start-8664.html
Thanks!
    • I'm suborn like that Ed. There's a plaque in my doctor office that says, "Don't quit, take a break." Works for allot of things.    Reality is, the wife loves her SUV and even given it's issues, she'd buy another if she found one with low enough miles. Then again she has me to maintain it.    Most of what ails this thing is GM shooting themselves in the foot and by extension the buyer. Besides a ridiculous breather system the cat warm up strategy, IMHO, is the dumbest thing I've ever seen an OEM do to a vehicle they warranty. On cold start it r-e-t-a-r-d-s the ignition to like -17* ATDC and dump fuel like kicking over a pail to force combustion in the CAT's for rapid warm up. This literally hoses the oil off cylinder walls and creates enough varnish precursors to stick rings in even well maintained engines. THEN if that wasn't bad enough they recommend using a wanting fluid specification at equally stupid interval.    Common to all GDI motors I'm aware of is this silly practice of driving the HPFP off the cam giving a leaking pump direct and unchecked access to the crankcase. And sir, eventually the ALL leak. Your job is to "catch it if you can". Yes, these are the same people that removed dipsticks from engines and transmissions in belief Joe Average wasn't capable of checking, reading and maintain his own vehicles fluids. Sadly  and in large they were correct. Most people these days can't tell a sparkplug from a fire plug.  Great ideas one and all.    Every move and every error calculated to defend themselves from the law and their own customers.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
