Got all 3 of my trucks in 1 shot. Been on those 2 since 8 am Friday with almost 9 hours left to go.
Sent from my SGH-I927 using Tapatalk 2
Here is a picture of my first GMC sierra, its a 2004 with the 5.3, z71.
Pro comp wheels and tires 265 75 16, cranked keys
Second picture is of my 2008 GMC sierra with the 4.8
This truck had 2.5" lift kit, with the same 16" procomp wheels,
Flowmaster 44 series
K&N CAI
The third picture is of my 2011 GMC sierra extended cab featuring,
factory wheels/tires
Flowmaster 50 series SI/DO
K&N CAI
RCX 4.75" lift
my most recent picture of my truck 4.75" lift with DC 2's, cooper discoverer 285 70 17's
2nd picture is with the 3"BL
Edited by Travis22
Well, having seen all the awesome trucks here, here's mine. Just a few teaser pics, more in my gallery and still a work in progress.
2011 Hennessey Silverado 1500 4x4 Crew Cab LTZ Supercharged 6.2 liter 6 speed automatic w/3.42 gears
Lowered with Macgaughys 4/7 with rear air bags for towing
Blacked out front grille and rear bumper
Escalade steering wheel, tahoe cup holder with custom switch panel and sierra denali armrest
Autometer gauge cluster in middle of dash
Drilled and slotted 4 wheel discs with red painted calipers and ceramic pads
Peragon bed cover
Black bezel headlamps with HID bulbs
LED rear taillamps with black bezel
Gm factory side cab, rear bed and bumper valance skirts
Foose wheels 9.5x22 with Goodyear Fortera LS 285/45R/22 tires all around
Chassis mounted air compressor with accessory hose on rear bumper and power plug for winch or booster cables
Dual black stainless steel rear exhaust tips behind rear tires
15% tint on front windows to match factory rear window tints
SuperChevy Sunday @ PBIR in West Palm Beach FL.
2011 Hennessey Silverado 3/4 rear pass side view
2011 Hennessey Silverado 3/4 front pass side view
2011 chevrolet silverado customized interior
Edited by 11hennesseysilverado
Old man (1957) in a Old shirt (sorta old shirt) beside an Old Truck (sorta old truck) :lol:
Guess I'll add a pic also. Here's my 2006 SS. Not much done to her so far. CAI, Magnaflow high flow cats and catback, and a tune.
Sent from someplace, somewhere probably during a burnout.
Some fine looking trucks ^ gentlemen. All one of a kind, and soon to be classics. Shout out to Simonsbp 1984, that color is incredible.
Guess I'll add a pic also. Here's my 2006 SS. Not much done to her so far. CAI, Magnaflow high flow cats and catback, and a tune. Sent from someplace, somewhere probably during a burnout.
Another one of you guys?
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
