I love the new camera. I played with both the 18-55 lens and the 75-300 lens. Won't have anything new on the truck for a while. I love that the cooler can be seen and if you look close you can see the painted brace.
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Edited by chawkins6789
A little of today
All truck supporting it. Well... With a WD hitch
That's a sharp Tahoe!
Sent from my SGH-I927 using Tapatalk 2
