Here is quick picture of my truck after I washed it this weekend
The De-badging/De-molding is dones, now I think its time to Rhino Line the Bottom
That looks great! I especially like it without the molding. How did you remove the molding? Was there any difference in the paints shade that was under the molding?
Thank You
I just removed it using a heat gun, fishing line, and a plastic scraper, plus 3M adhesive remover, 3M adhesive Remover Wheel, a 3 Step polishing systems, and lots and lots of patients.
No there was no difference in paint shades. But I did run into a couple other problems. When I removed the passenger side first, I noticed some bubbling paint. My paint guy said that it looks like that door was repainted and it was done poorly. Then I went back and forth whether or not I was going to do the other side, or put the molding back on. I decided to remove the other side and when I did I noticed a nice dent in the side, and I somehow scratched my paint taking the molding off of the rear driver side door. IDK how I did it, I have de-badged/de-molded a bunch of vehicles and never had a problem. Thats why Im thinking about doing the rhino lining on the bottom.
If you are interested in doing it there are tons of videos and walkthroughs online that will help you out. Just be very careful.
Edited by Diggerdan11
His didnt leave a ghost line but yours probably will, my 7 year old truck has a faint ghost line.
That's what I'm afraid of, and I really don't want that to be the result.
That car looks scared :lol:
Sent from my SGH-I927 using Tapatalk 2
Had new cluster lights done
Sent from my Samsung Galaxy S4 using Tapatalk 4
I think blacked out is growing on me
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
