Dual Amp Set Up Question Ohms, Watts, Speakers...
So I have been reseraching on the internet how to set up two amps for my truck, but I have some questions about ohms, and watts...I am going to be running four 6 1/4 Kickers off of a 4 channel amp, the amp was given to me by my brother-in-law, it is a little older but works great. It is a DHD NTX-2008 175 x 4. The kickers are 50watt RMS and 100watts peak and they are 4ohm speakers. From what I gather the amp produces 55w @ 4ohms with 4 channels;
http://mobile-emotions.com/dhdpowcruisa7.html
Now I a may be totally reading this wrong, but I think I will be ok running these speakes with this amp? My question is should I hook the speakers up in a series or parrallel? And if this amp would blow the speakers, can I prevent that by adjusting the gain?
Any help would be apreciated.
By the way I have my sub in and it is running off of a 50watt 1 channel amp, the kickers arent installed yet, just using the stock speakers.
Thanks in advance guys!
Ashton
Well in theory you will hook them up in parallel but since it is a 4 chan amp you will just wire each chan to a speaker, for the fronts you will lose the factory tweeters unless you wire them to the door speakers
I figured that much, thanks for point it out though, never thought about the tweeter, what I am really worried about is what will happen to the 50 watt speakers themselves, if I will blow them with the amp.
I have never heard of that brand of amp and for an amp to actually produce legitimate 175 x 4 it would be one hell of an amp, I mean you would be paying about $800 for that sort of power. I would say you are going to be just fine powering that speakers with that.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
