Got A New Truck
Not to steal your post, but I've ben waiting for my new truck patiently, and I thought I'd take a drive down to the dealer today (one hour away) and pulled around behind their shop and guess what was there!
Congrats we need pics. All you guys buying newer trucks makes me want to get a new one. But I'm happy with my 2007 V-Max for now.
Nice HD...
here are some quick pics, I'll get more of it later. Interior is two tone black leather with a white middle,kinda sharp looking,love all the features this had then my stripped SLE, feels like i'm driving a Caddy :dunno:
and yes no gas payments either (company card) but it's half my business hence the no 6.2 guzzler :)
Mods will be black bear tuned
corsa exhaust
toneau cover (hard) any recommendations?
and possibly a open K&N filter
Wanted a Linex but it has a GM liner in it already, so I'll probably just stick with it to save dough. I won't own the truck when it rots out :)
Did NOT want to part with my 05 pro sport but with the castech doo doo I didn't feel like dropping 4K into it with that and evap, abs sensors, steering was groaning etc etc..it needed some work. Like a years worth of payments. Plus it was an ext cab and with a kid I needed something a bit bigger
I like everything about that truck except the rims, they look like cheap plastic covers that one would pick up from Autozone or Checker. Congrats though on the purchase
corsa exhaust
check out the line-x tonneou cover looks great and many good reviews
personally i would go with an airaid jr kit over the k&n http://airaid.com/ProductDetail.aspx?ProductID=201-796
i have the k&n but only because airaid didnt have a kit for the 09+ when i got my k&n
i also have a blackbear tune i like it and it does make an improvement but im questioning if its worth the money... when i eventually get a supercharger it will be for sure but only paired with an intake and exhaust.... im not sure..
I added an Extang Solid Fold tonneau and am happy with it so far. It kept just about all the water out of the bed when I took it through a carwash Friday (water made it in from the bottom and sides of the tailgate area) and it removes easily if I need the whole bed for something tall.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
