How-To: Level Towing Mirrors.
So I finally got my towing mirrors in for my 2004 HD after waiting about 3 weeks due to a shipping backorder. I got them installed and like many other people have complained, they had a pretty good lean to them. I did a little research and decided to "level them." He is a quick write up with pictures. I did not take any pictures of removing the door panel, as I had done that already before I thought about taking pics.
Here is a before level picture. See how the mirrors leans uphill?
Step 1
Remove the plastic trim covering the pivot on the mirror. From the front of the truck you want to push down a little and towards the rear to release it.
Step 2
Remove the 4 screws that hold the mirror pivot to the base.
Step 3
Take the mirror hinge clamp off. Go to the local hardware store and get some washers to shim the top bolts out. I went to Home Depot and found stainless washers, lockwashers and longer screws for $5. The stock screws were long enough, but I wanted to ensure I had full length of threads holding. Mine were m5x.80 threads. Also my mirrors are aftermarket made by Koolvue. I believe the stock GM mirrors have phillips screws. Either one works the same.
Step 4
Install the longer screws through the top holes in the clamp and I added 4 washers between the clamp and the base. They were pretty thin washers. mirrors013.jpg
Step 5
I cut a small piece of rubber hose and put it behind the top mirror pivot "saddle" to take up the slack created by dropping the top of the mirror outwards. mirrors011.jpg
Step 6
Install the mirror, clamp, and screws and tighten back down. You may need a helper for this part. It is hard to hold everything and start the screws. mirrors014.jpg
Step 7
Check the fit of the plastic trim piece that covers the pivot. By tilting the pivot it will rub a little on top. Check the fit and trim with a dremel tool or air grinder and carbide bit to fit. Snap back together and have a cold one!
Before
Here is a picture of before and after leveling.
Hope this helps anyone wanting to do this mod. Its just a quick write up, as my camera work isn't the best.
  • 1 month later...
Great post. What do those mirrors cost? I have the telescoping ones on mine. The passengers side does not extend without some help.
I found a new aftermartket set online for about $300.
  • 5 years later...
Thanks for this post. I just got mine from ebay ($100). Heated/turn signal power mirror (manual telescoping). I was able to get mine leveled too, but what a PITA. I did not put any rubber hose behind as there was 1 bolt on each side that would not come off. Hopefully they won't shake up and down???
    • Idler Pulley… from what I understand GM and Chevy trucks no longer have an idler pulley.. they stretch belts for both belts… I had mine replaced by my local mechanic last year on my Chevy Silverado 5.3 z71 LT.   They have discontinued using them on 2019 through 2026 as of a Google search.
    • Good morning! I have a whirring sound coming from the engine or transmission area when driving w/o towing when I accelerate at 1100 rpm’s. That’s how it started. Yesterday it was more obvious while towing a U-Haul even when not accelerating at 70 mph. I could see where it may have been possibly shifting gears due to a slight grade and the intermittent rpm changes as the transmission was possibly lowering the gear down. It was making the sound multiple times but it is not constant. I replaced the serpentine belt and idler pulley but no change. It only does it when I’m driving. No noise accelerating while in park. Just started @ 53,000 miles. It’s not always there though. Unfortunately, I feel it may be transmission related. Any thoughts or knowledge about the 2022 tranny that anyone can share. I have 2500 miles left on my p-train warranty. Thanks to all for any help!
    • RAIN. It's dumping buckets. We needed it. What a welcome change...sitting here listening to it pour with my office window open.   Ok, not too much. It's not even September yet, we're not finished with summer yet....
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
