Silverado Vss Wire
where is the easiest place to tap into the VSS wire on a 05 silverado for aftermarket Navi..... i already looked in the easy spot behind the radio but i dont see it there :)
Here are the instructions I used to tap into the VSS for factory nav upgrade on my 2008 Sierra. It might be different from your '05 but check it out...
"Under the dash on the drivers side near the parking brake, you will see a black plastic cover. Remove this cover and you will see a wire terminal box. At the top of the terminal box you will see a clip on each side. Squeeze them together and pull the box towards you. You will see on the bottom a lug on each side. Lift up and gently turn the wire terminal box clockwise so you can see the back. You will see two blue levers. Looking at it, the one on the right side is where the vss wire is located. It is the green wire with the white tracer. Located in H1 slot. There is another green wire right below it. It is on the right side about halfway up the box. Using a red 3m connector splice the green wire from the vss kit to the green wire with the white tracer. "
