Waiting For The 2nd Tow In The Past 6 Hours
2002 sierra 1500 98k 4x4
Fuel was getting low this AM so I threw in a quick 20 bucks worth of gas. Ran fine for 40miles. Then it started to buck. Pulled to the side of the road. Idle is very sparatic then stalls out.
Got towed..... figured it must be bad gas. Threw in some drygas and it seemed to run fine. Drove 4 miles to get new gas put in and a half mile from the station...the bucking started again. Got it there, filled it up and threw in some injector cleaner. Pulled away from the pump to a parking spot and idle is once again sparatic and can't keep it running.
Put my scanner on it and NO codes are coming up.
TPS?
Fuel Filter?
Thanks guys
Check filter fuel pressure regulator and fuel pump pressure
what is the fuel pressure suppose to be on these?
I'm assuming 43 psi but don't want to assume anything
put a fuel gauge on the fuel rail and have 0 when turning on the key.
Replaced the fuel filter and still the same reading
Before I jump the gun an think its the fuel pump can anyone tell me where the fuel pump relay is and how to test?
Also read to look into my regulator?
Connections on top of the tank look clean and have good good contact from what I can see.
I'd say you got some water in the gas from the station. Go back to where you bought the gas, I'll bet there were a few other people with the same problem.
I used to be in the business of managing the maintenance for a large multinational company. Every underground gas tank will have a certain "heel" of water/sludge collecting in the bottom of the tank. When there got to be too much, I used to send in a pumper truck to suck it out. Normally, the water and sludge sit undisturbed in the bottom of the tank. The station pumps suck from maybe 6" from the tank bottom. However, when a tanker comes to drop in new fuel, it disturbs the bottom sediment and it swirls around and gets sucked up by the station pump and pumped into your truck.
Moral of this story, if you are pulling into a service station and you see a tank truck there, just keep on driving to the next station. Of course, the truck might have just pulled away and you could still get sediment. Or he could be dropping a different grade of fuel and you will still be okay. If the station is a mulinational brand, they will offer some compensation to you. The gas tank might have to be cleaned and fuel filter changed or just fuel filter changed a half dozen times until it is all out.
Usually fuel pumps either work or they don't so I wouldn't think that would be the problem.
the fuel pump relay is located in the electrical panel on top of the driver side fender. fuel pumps in chevy trucks like to go out when you run the tanks low on gas, very common.
Try smacking the bottom of your gas tank and see if it works then. (seriously). Sometimes it will make the pump work for a while until you can get to a shop for a permanent fix. At least it may get you off the side of the road.
Agreed!! Turn the ignition key to ON and then swat the underside of the tank with a 2x4 or baseball bat. It helps if somebody is in the truck to turn the engine over while you take out your frustration on the tank. That can get the fuel pump to start running for a short time.
Unfortunately, replacing the fuel pump is not a simple task.
... and not changing the fuel filter at recommended intervals kills them too. (I have personal knowledge of this phenomena :sigh: )
GM started putting the in tank filters on 04 and up when they went to the return less fuel system..some 04 flex fuel trucks still had a external fuel filter, so you may need to look..
    MASONV88888888
    MASONV88888888
  • Who's Online   2 Members, 0 Anonymous, 1,611 Guests (See full list)
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
    • Do you have access to BP fuels? Some stations have Silver 91 E-0 priced the same as their 93 E-10.  There is a local Marathon with 90 alky free for $6 a gallon but I go down the road to BP for $5-ish. They also have a 100 E-0 but that stuff is $10 a pop.
