Another Air Suspension Question
Hi,
New to the forum. Thanks in advance for all the help. 2003 Denali with Z55 autoride. Seems like I am suffering through the diagnostics process like countless others.
Pump stopped working and have dash message.
fuses ok
pump works on bench
relay is ok
height sensors ok
"No ground" condition at ALC relay.
Do I check relief valve soleniod by jumping blue and white wire at pin connector?
Do I check hi-pressure switch by jumping orange to green at the switch harness?
Anything else to check?
