Snowplow Prep Package 2011 2500
juniorbeloin
i just bought a 2011 2500 whit a duramax. i dont have the snow package. will i be able to instal a plow instalation kit (from fisher) whitout major modification?
What configuration is your truck?
Here's the actual listing for the snow plow prep package for your HD. Review it and you decide.
Snow Plow Prep Package, includes 10-amp power for backup and roof
emergency light, high-flow front bumper, forward lamp wiring harness,
(TRW) Provision for cab roof mounted lamp/beacon, instrument panel
jumper wiring harness for electric trailer brake controller and (NZZ) Skid
Plate Package
1 - Requires 4WD models. Includes (KW1) 160-amp alternator with (L96)
Vortec 6.0L V8 SFI engine. Includes (K76) dual 125-amp alternators with
(LML) or (LGH) Duramax 6.6L Turbo Diesel V8 engine.
Just a warning that GM has been known to deny any and all
warranty service on any GM truck with a snowplow that doesn't
have the factory VYU plow prep package.
Pre. 2011 GM gmt-900 fullsize diesels (except reg. cabs) did not offer the VYU plow prep. option. Not sure about the 2011s with the new frame.
Best to talk to your dealer................
Also note that some/most snowplow dealers will NOT install certain
snowplow set ups on certain trucks because they overload the front
axle aka the FAWR rating because of liability concerns.............
Check the Fisher plow site and type in your truck model, options etc.
into their snowplow selector gizmo. That will tell you which plows
that will work with your truck....................
VYU is now available on all HD models across the board, starting with the 2011 model year trucks.
Anybody have a clue what this costs to add to a HD truck with the Duramax after the initial purchase?
Different body wiring harnesses, front bumper and second generator with an engine wiring harness change??? I wouldn't even want to guess but I'm sure its a lot less when ordered on the truck before taking delivery.
Tanks for the advice. i dont mind about the roof light,skid plate and alternator(small drive way,personal use). I am worried about the wirring harness for the light(foward lamp wirring harness in the plow prep package). And by the way what is instrument panel jumper wiring harness for electric brake controler(i already have the factory indash one).
Don't forget the front GAWR is less without VYU. VYU with a Duramax gets you a 6000lbs front GAWR versus 5200lbs (might be 4800 but I dont quite recall) without it. The torsion bars would have to be swapped also to accomplish the higher rating.
  • 5 months later...
Plate Package
there is more to it than that...look it up.
Plate Package
That information was pulled from the actual sales information so I'd suggest if you want to HELP and CONTRIBUTE to this thread, how about posting up what you have instead of acting like a pompas assed smart mouth.
Plate Package
F U you idiot... I couldn't there was a problem with me loading it up. But I'm sorry for assuming you were smart enough to know how to use a search engine on the internet.
I don't need an internet search engine when I have the actual information from GM therefore (looks like I'm going to have to lay this out so even a 2nd grader can understand it) I asked you to prove what you're talking about instead of claiming you know more than the sales guide. Too difficult to understand? Obviously.
