Engine Will Not Turn Over
i have a '01 1500 hd 4wd, tow and plow . went out started truck and drove off, had to return home 5 nminutes later. when i went to restart truck 3 mins later the only thing i got was a click from the starter. the dash lisgts and radioa all come on. when i turn the key and get the 1 click from the starter, the odometer and radio lights go out but rest of dash is lit. I'm thinking ground first and then starter. The only ground i see is the one from the battery to the block (btw, how the hell do you get down there to loosen and clean it?) where are the other grounds. The battery is less than 1 year and tests at 12.4 at rest. i know this may sound low, but my car batteries test around the same and start the cars with no problem. is there anything i'm missing?
I'd start with testing the battery under a load, then start looking at the cables. Being it's an 01, but not knowing where you live, I'd say it may be time for new cables. They can corrode up in the insulation where you can't easily see it.
Take the battery out, and take it to the auto parts store to get it tested. If it tests okay, then it will probably be your starter. Take a piece of wood (lumber), and hit the starter casing a few times, and try to start it. If it works, then your starter might be on its way out and needs replacement.
thanks. i had the battery tested and it was no good. got a new one and truck still wont start. next step will be to remove starter and bench test it. if that works then it on tp the cables .
    • No.   That would be an LT and higher trim.  Passive entry.  There would be a little button on the door handle and you can program it to proximity lock or unlock.     WT and Custom do not get this feature.
    • Mediocre, how much did they lose on the poorly conceived EV strategy?   I wonder how much the stock price is being 'inflated' by all the buy-backs?   Cadillac literally looks like a brand without a rudder, no clear goals or product direction - performance or luxury? I guess performance because we can throw a small block in whatever we can and call it a day. Certainly not luxury when a Denali or High Country is reasonably cross shoppable. The Celestiq - no way - no vehicle can command quarter million prices when something wearing the same badge is on the buy here pay here lot across town.   Notice the 'base' Escalade doesn't even come with the 'leather-appointed' seating surfaces.   Hummer EV - fail Silverado EV - fail Sierra EV - fail Bolt/Volt EV (The most successful EV cancelled, restarted, cancelled, whatever its current status it)   Hybrids - none Sedans - none Medium duty - not anymore Minivan - none Coupe - none Convertible - none CUVs - 20+/-   6.2 Recall that landed squarely on the GMs highest seller - and specifically the fattest margin higher trims of the Yukon, Escalade, et. al. The most critical product line they fumbled big time. In the Escalade segment, are those buyers forgiving GM for a bad engine and patiently waiting for the fixes and dealing with the headaches? Nope, they dump them and go straight to the other premium brands.   In the ENTIRE GM portfolio how many aspirational vehicles are there? Corvette, Escalade (quickly being superseded by the obvious better value Denali)...   I posted somewhere else... what if Cadillac left the luxury game and became a performance brand similar to AMG or (gasp) Ferrari? Cut all the entry-level and base models from their line up and focus on the V-series or Blackwing or whatever they call it now. Of course, those would have the pre-requisite luxury and technology as standard equipment. This opens the floor for Buick to step in/up as the luxury brand (like they are in China), no 'performance pretenses' get rid of the 'entry-level' models with equally 'entry-level' power trains and become the Maybach to Cadillacs AMG. With those two brands effectively out of the way Chevrolet, the 'entry-level' brand has the floor to itself and GMC can take over as 'professional grade'.    Now each brand has a focus, no in-fighting, clear direction, and customer targets.   Just need to sneakily slide Corvette into the Cadillac brand and dump the vestigial script writing.
    • I can't get enthusiastic about the 1.5T (or the 1.3 or the 1.2), I won't drive a CVT. But the stupid things sell in volume.
    • There is a big difference in motorcycles and vehicles - nobody needs a motorcycle, they WANT one. That WANT is the most powerful force to drive price upwards.   I've hated every iteration of the Equinox, a prime example of GM laziness. It excelled at absolutely nothing, barely competitive by every metric. At least the latest generation looks decent.    I want to like the Buick Envista, but that pitiful engine plus FWD only is a BIG NO for me, I don't care how good it looks.
    • For as much hate as Ms. Barra receives on here, she sure is a shrewd businesswoman....
