New Toy
97Z71
Looking good.  That was a great time taking the tour down there last year.  I think someone mentioned a possible meet down there next year over the summer, anyone?
Thats awesome that they let you take pictures!
Isn't the part were they mate the body and chassis amazing???  :eek:
your mean!!!  :angry:
haha NICE CAR enjoy it
:puke:
So where was that pic taken?
Inside the vette plant.
