Buying Auto Parts
ibreakeverything
I recently bought a shock for an old second hand truck I'm trying to fix up, and despite telling the person that it's a 2000 GMC Sierra 2500 4x4, he gave me the wrong one.
Out of curiosity, does anyone know why there would be so many differences between trucks of the same make/model/year? What information would I have to give to make sure I get the right part?
I'd like to buy online too since it may be cheaper, but I wouldn't want to get something for a 2000 GMC Sierra 2500 4x4 and find out it's the wrong part.
There were actually two different body styles of 2500 trucks made in 2000. Sometimes the parts places get confused by this. If you have the older body style, your truck looks like a 98. If its the newer body style, your truck looks just like a 01-02.
I see. From the looks of it (using google image search), mine is a new body style. I'll remember to mention that next time in case that changes things. Also it seems to be a heavy duty version, so I'm sure that changes things as well.
Does anyone know of any good online part stores that ship to Canada?
They should ask you if you have the Classic or Silverardo or Sierra. If you tell them the new body style they should get it but not always. I get that sometimes with my 99. :lol:
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
