Pin Striping
FarmGirl92
I have been trying to decide for a while now if I should keep my pin stripe or remove it. I've been leaning toward removing it, but I'd like a few more honest opinions (keep in mind I did not put the pin stripe on, it was already on the truck when I bought it).
Woah...I absolutely love your truck. And thank you for the advice...I've for sure decided to take off the pin stripe, but I hadn't thought of the chrome trim. Would that honestly look alright?
Thankyou, and yes it would be a HUGE improvement IMO.
I would remove the pin stripe on yours. I like the fender trim though. I am a chrome person though. I'm still trying to decide if I want to leave the pinstripe on my truck or not. I go back a forth about it.
I know exactly how you feel. I've been back and forth about mine for a couple months now, believe it or not. I was going to take a pic and photoshop the pin stripe out, but then I decided to just get some other opinions on it. And I'm thinkin' that removing the chrome trim would be a big hassle...I might have time to do that later on, just not now. But if you still can't figure out your pin stripe situation, try photoshoping it out. If you don't have photoshop, maybe try asking for some outside opinions.
Remove. Take the chrome fender trims off with it. :thumbs:
my feelings exactly. i took the chrome trim and stripes off my truck and it made a world of difference.
this is the truck when i bought it:
took off the trim and stripes and a few more mods. you can see the after pic in my sig. its amazing what a few simple things can do for your trucks looks. good luck and hope that helped ya any :(
I removed the pin stripe, and it's a major improvement. And I'm still considering the chrome fender trim, but honestly I'm not sure how to remove it. I don't want to mess up the paint or anything by making a simple mistake.
They are either on with screws or double sided tape, you will be able to see the screws if that is the way they attach and if you cant see any screws it is tape
Well either way, will it come off clean or will it look as though something was removed? If that makes sense.
I like stripes on the truck. I would like to put stripes on my Escalade very much. But I do not know, where them to buy :dunno:
Have you checked places like Autozone? The accessories section should have them. :D
i personally would take off the pinstripe, i see you did that already which is good. definatley take the chrome trim off, and definatley take the useless bedrails off
