Fng Lookin At A New Truck
I own a 2008 Dodge Ram and am looking to trade it in on a 2011 Silverado Extended Cab Z71 4x4.
I test drove two different trucks and they are night and day different.
The first on is this white one
http://www.jerryschevytexas.com/VehicleDet...d-TX/1213785103
It really felt like a scalded a$$ed ape the way it ran. It pulled hard and would start to leave two black marks if you didn't lift up. On the highway, cruise control set on 60 mph, the best mpg I could manage with the system reset was 18. I drove the truck close to 100 miles throughout the day so I'm pretty certain that is what it is capable of.
The second truck, the one I really want to buy because I think Black/beige is just too good looking......drives totally different.
http
://www.jerryschevytexas.com/VehicleDet...-TX/1225626453
As you can see, both trucks are the same price, have the same options, and other than the color, are the same truck.
Yet the black one one, when driven on the same highways as the white one, would get as high as 23 mpg on the computer..it didn't pull as hard and would only chirp the tires off teh line. It felt smoother and was easier on the computer.
It honestly feels like the white truck has a 3:42 gear ratio and the black one has a 3:08 ration.
Both trucks have the GU6 RPO code in the glove box so I'm curious what ya'lls opinion is on this.
I'm going to try to buy tomorrow. 8 grand off plus dearlership loyalty/military discounts is too good to pass on.
Are the computers that far off or is there that much difference in driving all the trucks? Temperature was the same on both days. Both trucks had nitrogen filled tires and the same amount of gas.
I've read a lot of forums lately and sounds like some people get really bad mpg's yet others are happy.
I'm lucky my neighbor is a general sales manager so I can test drive anything I want for a day.
  • Replies 36
its as simple as gear ratio, with the taller gear you will get shittier MPG's but better performance. it all depends what you want, i personally would go find the truck you want.. a black one with at least 3.42's
that black truck looks really nice with the tan
I agree it looks pretty good.
I want the truck that gets the best gas mileage.
The black truck shows it has 3:42 gears on the sticker, and it has the RPO GU6 in the glove box.
I'm just wondering if GM didn't make a mistake or the trucks are programmed differently or what.
are you sure they are both 6.2's?
They are supposed to be identical. Both have the LC9 RPO so they would both be 5.3L.
I did notice going down the highway, cruise set on 60mph, the white truck would not go under 1700 rpm and the black truck dipped down to 1400 a couple of times.
I know manufactures don'y make mistakes often, but it really looks like the gear ratio posted in the glove box and on the sticker and the the ratio that is actually in the differential may be two different things.
thats very weird.. you should have the dealer run the vins... and i guess check over the build sheet closely one more time. from reading the specs on the trucks from both links, it says they are both mechanicly the exactly same
Jack them up and spin the rear tire 1 revolution mark the drive shaft and count how many times it goes around.
That will tell you if the gear ratio is different between the two.
I would get the one you liked the best. They shouldn't drive that different if they have the same engine and gear option. If one ran much better than the other, then thats the one I'd go with. They shouldn't be that different. Both are great looking trucks so I'd pick the one that ran the best. If your that worried about mileage, then I'd consider finding one with the 3.08 gear option.
Were the weather conditions the same both days you test drove the trucks? Cooler weather would make a difference verses hot weather.
Both are nice looking trucks, get the one you like. I like the white cause scratches dont show as bad but that is me. The black is better looking thow.
Looking at the online window sticker, they both have identical options other than color. They should have driven very much the same :)
I'll do that!!
Only because of the RPM's at 60 mph were 300 apart.....
1700 on the white one and 1400 on the black....
Yes as mentioned above, the weather was the same on both days, and I even drove on the same highway to be sure.
I hear ya on the scratches. I'm tired of white trucks, I dunno I've had a few.....that black and Tan truck looks really good in real life.....
I just need to check up on the rear ratio.
I'm not too concerned if it's a 3:08 because that will pull just as well as a 4speed with 3:73 gears according to all the things I have seen because of the 6 spd gearing.
I'd sure like to know what is going on though. The RPM difference is enough for me to double check. If I'm paying for a 3:42 I need to make sure that's what is in it.
I think all z71 4x4's are 3.42 by default. I'm sure someone will be along shortly to correct me if I'm wrong. :)
Nope, Z71's also come with 3.08's
Knew it! Doesn't make much sense to me to have a 4x4 truck with a 3.08 ratio though. Nonetheless, both of the stickers of the trucks the OP posted show that both of these trucks have 3.42.
Well I own the black truck. It looks too good. Come to find out the white truck was in the service dept....
My guess is 6th gear wasn't working? I dunno.....
I set the cruise on 60mph on the way home....30 minute drive and averaged 22.3 mpg. Not bad from a full size 4x4.
Kinda strange GM uses drum brakes on the rear.....
I noticed Toyota Tacoma's do as well.....
Oh well I can start my truck from my phone and unlock and lock the doors now lol. That's pretty cool.
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • Are you playing Slide Down endlessly but your score is still low? Are you constantly crashing into obstacles as the game speed increases? Don't worry, this article will share 5 invaluable tips to help you master the race and impress your friends. Golden Rules 1. Look one step further. The mistake of 90% of new players is only staring at their character. The secret of experts is to look towards the top of the screen (where the slide is about to appear). This gives your brain an extra 0.5 - 1 second to process the situation and determine the direction of movement before the obstacle approaches. 2. Use gentle movements; don't swipe too hard. Slide Down is very sensitive. Moving your finger too forcefully or with excessive amplitude will cause your character to be thrown off course or crash into a wall. Practise moving your finger with small, decisive, and precise movements. 3. Don't be greedy for gold in dangerous locations. Gold coins are tempting for buying skins, but life is more important. If you see a gold coin right on the edge of a cliff or next to a spike trap, ignore it. Our goal is a High Score, and your score only increases if you survive. 4. Make the most of Power-ups. During the slide, you'll encounter items like Magnets (attract gold) or Shields (temporary invincibility). Never miss them! Especially the Shield, it's your "get out of jail free card" to help you get through those deadly fast sections. 5. Stay calm when speed peaks. When your score exceeds 500 or 1000, the game speed will be very fast. At this point, don't try to think logically; let your natural reflexes work. Take deep breaths and don't panic. Apply these 5 tips to your next game, and your leaderboard will surely improve dramatically. Good luck climbing the Slide Down leaderboard!
    • If you use compressed air regularly, one problem you cannot ignore is moisture. Water in the air line can cause rust, unstable air pressure, poor tool performance, and even damage to sensitive equipment. That is why I highly recommend using a desiccant air dryer. A desiccant air dryer is designed to remove moisture from compressed air by using drying materials such as activated alumina or molecular sieve. Compared with basic water separators, it can achieve much lower dew points, making it especially useful for applications that require dry and stable air. For workshops, painting systems, pneumatic tools, CNC machines, laser cutting equipment, and industrial production lines, a desiccant air dryer can make a big difference. It helps protect equipment, improve air quality, reduce maintenance costs, and extend the service life of the whole compressed air system. Another advantage is reliability. Many desiccant air dryers are built for continuous operation and can maintain stable drying performance even in demanding environments. For users who care about long-term efficiency and equipment protection, this is a smart investment. When choosing a desiccant air dryer, I suggest paying attention to air flow capacity, working pressure, dew point performance, regeneration method, and maintenance requirements. A good model should match your compressor system and actual air consumption. Overall, if moisture is causing problems in your compressed air system, a desiccant air dryer is definitely worth considering. It is practical, efficient, and highly useful for anyone who needs clean, dry, and reliable compressed air.
    • My brand new 2007 Silverado's wax frame was rust from end to end partway through it's SECOND winter here in MA. That stuff is completely useless.
