New shotgun barrel
zach1990
just bought myself a single shot stevens model 9478 12 gauge for a great deal of $35! my only problem is its a smooth barrel and i want to add a choke. does anyone know of a good website to get a new barrel that will accept a screw in choke? id appreciate any help
gunpartscorp.com
Might try them, thats who I was refered to from another forum. I'm trying to track down a barrel for a Springfield 67H 12ga. Unfortunatly, I found out after alot of googling, that mine is a fixed barrel. So I guess I have to get the receiver/barrel combo now.
you might try midwayusa.com
They have very good prices.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
