Remote wire with stock HU
I did a search on this site and another and Im finding so many different things. Where can i connect the remote wire for my amp if im keeping the stock head unit? I saw one guy reply with a link to another thread that had you make this wiring harness but it seemed like that was to actually get power, but i just want a remote line. My amp will have a 4 guage line off the battery. Other threads listed several different colored wires under the dash and some in some plugs under the dash. Please give me a difinitive answer for this. Thank you.
Forgot to specify its an 08 Silverado CC. LT no bose.
There is no true amp turn-on lead from the factory deck. Best you can do without adaptors is to wire it to RAP accessory power (pin 8 in "X14" port of left I/P junction block - it's the black covered panel to the left of the brake pedal - fourth port down on the left side, pin 8 is bottom left pin). This will turn on the amp whenever the key's on, regardless of whether the radio is on or not.
Another way you could do it would be to wire what's called a "trunk-loc" , which provides a turn-on output when it senses voltage on the speaker leads (ie; when you turn on the radio).
If you're never going to turn off the radio when you're driving, the first method is perfectly fine. if you like to drive in silence sometimes, spend some $$$ and do the second method.
i ran a hot wire on a toggle switch for over a year and never had a problem. all the amp needs is current on that pin to switch on, and no current it goes off. i hid my switch on a bracket i made under the dash next to the obdII port.
How are you sending signal to the Amp? Speaker level inputs (using the stock speaker wires into the amp)? Why don't you try a PAC Audio adapter? I just put one in and it has a remote turn on lead for the amp. It is true plunge-n-play, no cutting wires, plugs directly into factory harness and gives you 4 RCA outs. http://www.pac-audio.com/productDetails.aspx?ProductId=366&CategoryID=28
I ordered mine from Amazon and it was less than the $54 it quotes on the site. Proab the easiest and cheapest way too add an amplifier to your truck and retain the factory speakers if you want.
It seems like most people have engine noise with those. Also I havent seen a solution for the chime loudness issue with these.
Engine noise usually comes from running your RCA cable too close to power wire (usually the one that is supplying the amp as well). Good quality RCA's are insulated and shielded enough to keep most EM interference out, but you still shouldn't run even the highest quality RCA right next to power cable.
I'm actually using a JL Audio CleanSweep. I just pulled the Adapter Harness off the PAC Audio unit, cut off the input plug and rewired it to a matching 14 pin Molex plug connecting the two. I haven't used it yet since I am still in the process of installing all the door speakers and Fatt Matt. I just finished the roof today and the doors should be done by Friday with the speakers installed and wired.
I dunno, I would give it a try and if you get engine noise just return it.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
