How do I change the headlight bulbs in my 2008 Silverado?
I already said why the pins won't work anymore. I did stop at one Ford dealer and one Chevy dealer but communicated with 3-4 of each over numbers before visiting in person. And honestly at the time the only thing that stopped me from considering Ford was that I couldn't get an FX4 (the only trim I'd consider, I don't like chrome) with a column shifter, I didn't want that huge floor console. But now after reading some of the growing pains the Ford has had I'm glad I went with GM.
If you were an automotive design engineer, that may have some credibility. But since you're not, it's just a fanboy excuse.
Whatever you say. :lol:
I bet even the guys on the Ford site are tired of you being such a fanboy. :lol:
Good luck with the failing injectors and miles of timing chain that will surely fail on those trucks, which will probably require cab removal for any major work, because I haven't seen a single Ford since 1997 that looked like any thought was put into the underhood layout.
What Ford site? Too bad you FAIL once again as I belong to exactly zero Ford sites. :lol:
Ok enough LET IT GO, this topic is for changing head lights.
Sorry to burst your bubble bud
Drive to me and I will be very happy to take your money as I impress you beyond belief :cheers:
The first time it will def take you longer, however, when you have the tools in your hand and you have changed some around 6-8 times it becomes too easy.
MAYBE the driver's side, but no way in hell can you remove the airbox, change the bulb and replace the airbox in 5 minutes...I don't care how many times you have done it. And another question, WTH do these bulbs requre such frequent changes? I never replaced the headlights in my GMT800 until it was about 6-7 years old, I had to change both of the ones in my GMT900 within 3 years.
Yes sir. I've changed a set in my '08 I had, and changed some for my grandad and buddies. Actually the air box is easier than the passenger side. Loosen the clamp with a flat head (10 seconds), disconnect MAF sensor(2 seconds) and pull up on the air box, it pops up (5 seconds) and you can then fit the hulks hands in for the passenger side bulb.
OK, I'll give ya that...now that I think about it, the airbox was less of a pain than the washer reservoir. Why don't you do the OP a favor and go take a video of the driver's side...should only take you 5 minutes after all. ;)
High beams changed out... Tomorrow my low beam bulbs will be in. Can't wait it's totally night and day from the factory bulbs.
  • 3 weeks later...
  • 2 years later...
I visited this group because I lifted the hood of my 2013 Sierra HD Diesel to change the driver side low beam lamp and said, "Oh, crap". I read through this thread and now I see why some folks think it's easy and others just take it to the dealership.
Apparently, the "easy" instructions posted in this thread are for a gas burner. Diesel...that's a different story. Here are the steps I had to go through just to change a lousy headlamp.
1. Skip to step 4 if you're already in a foul mood.
1a. Remove the plastic shroud from above the radiator so you can get to the
second, hidden screw on the headlamp assembly.
2. Remove that screw and discover that it did absolutely no good because there are apparently other connectors down low that you can't easily get to. Get a magnet to retrieve the metal shim that dropped when you removed the screw.
3. Put the shroud back on.
4. Remove the bracket that runs at an angle across the top of the battery to the fender (two batteries...this is a diesel rig).
5. Remove the battery.
6. Remove the top screw from the washer reservoir and discover that access to the second screw is blocked by the battery holder.
7. Curse a blue streak and then scour the neighborhood for a ten-year-old
with really small hands unless you really just want to remove the battery holder.
8. Flex the neck of the washer reservoir back as much as you dare or, if you can manage it, squeeze your hand (the 10-year-old's hand) around by the fender. Rotate the lamp holder toward the fender and pull back. The lamp holder should come out. Replace the lamp in the holder and threaten the 10-year-old kid with bodily harm if he touches the glass of the lamp.
9. Align the slots on the holder with the headlamp assembly and rotate the holder back toward the radiator. Replace the screw in the washer reservoir, the battery, and the rod that ran across the top of the battery to the fender.
10. Curse GM because it look 30 minutes to change a lamp in a '13 Sierra that took me three minutes to replace in my '03 Silverado diesel.
    • I'm suborn like that Ed. There's a plaque in my doctor office that says, "Don't quit, take a break." Works for allot of things.    Reality is, the wife loves her SUV and even given it's issues, she'd buy another if she found one with low enough miles. Then again she has me to maintain it.    Most of what ails this thing is GM shooting themselves in the foot and by extension the buyer. Besides a ridiculous breather system the cat warm up strategy, IMHO, is the dumbest thing I've ever seen an OEM do to a vehicle they warranty. On cold start it r-e-t-a-r-d-s the ignition to like -17* ATDC and dump fuel like kicking over a pail to force combustion in the CAT's for rapid warm up. This literally hoses the oil off cylinder walls and creates enough varnish precursors to stick rings in even well maintained engines. THEN if that wasn't bad enough they recommend using a wanting fluid specification at equally stupid interval.    Common to all GDI motors I'm aware of is this silly practice of driving the HPFP off the cam giving a leaking pump direct and unchecked access to the crankcase. And sir, eventually the ALL leak. Your job is to "catch it if you can". Yes, these are the same people that removed dipsticks from engines and transmissions in belief Joe Average wasn't capable of checking, reading and maintain his own vehicles fluids. Sadly  and in large they were correct. Most people these days can't tell a sparkplug from a fire plug.  Great ideas one and all.    Every move and every error calculated to defend themselves from the law and their own customers.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
