Spark Plug gap decrease with mileage???
I know it sounds backwards, but can a gap on a spark plug decrease over time? I just changed my plugs today and when I checked the old plugs gaps they were set at .030. My manual says to gap them .040 so thats what I gapped the new ones at. Anyone ever seen this before. I assume they are the original plugs since the truck is about to roll over 100K, but I could be mistaken since I bought the truck with 87K on it.
Usually they open up, if they do change, What brand and part # did you pull out? If you bought iridiums they shouldn't have needed to be gapped. You have to very careful if you do gap them, 'cause you can damage the fine tip.
Never seen a gap get smaller before. However that's not to say someone didn't gap them incorrectly before you. I do know earlier in the 800 model years the gap was originally .60" then reduced to the .40" that's in our manuals so I don't have any real ideas of how this wouldv'e happened on their own.
Well, the ones I took out were AC Delco. I bought new AC Delco iridium plugs and I did have to gap them. THey were about .030 - .035 before I gapped them.
Should I have left them alone?
What is more efficient, a larger or smaller gap? Obviously if you get too far either way its gonna cause a misfire.
They should have already been properly gapped (0.40"). From what I've learned if they are not gapped right, take them back as they should not be adjusted. Any gap other than what is specified for your truck (smaller or bigger) will cause problems. IMHO take those plugs back and get them exchanged.
    • First off pay close attention to what Newdude pasted as he is a GM tech !.    I have a couple of questions which might cross off some questions others on this forum would be wondering about as well. So when was the engine oil changed prior to this trip, was it almost brand new oil or did it already have a fair bit of use on it before you started the trip.   Did you check the oil level on flat ground and was it at the full mark just before leaving on this trip which I gather from google map is about 700 miles or so. Why I ask and this is not the first time in history that has happened, that either a dealer or some other shop changed the oil on the vehicle and the vehicle left the shop and the owner ( you ) assumed the engine oil was full but in reality the person who changed the oil simply did not put enough oil into the engine .. it happens !. Also that a shop put the wrong viscosity oil in and an engine was not happy with that thinner viscosity and oil got past the rings at a higher rate than the proper viscosity. Not to mention if there was any leaking out of a drain plug or the filter gasket etc.
    • You could, although in the end it really doesn't make much difference what comes out in exact terms since it comes down to putting enough back in so that there is enough volume so that something flows back out once the trans is up to temp for the check procedure. I presume your putting a pan on that has a drain plug but its probably the same pan mold/size as at least a while back no extra volume pan was made for the gas truck version due to the exhaust cross over pipe issue. All I can say as per volume I put back in and this was based on changing out the filter as some is trapped in it that does not come out until its removed because of the way its made inside and my truck had sat over night with the trans having been hot when shut down and dripping internally before I pulled the pan. I went off of what the trans shop suggested as a minimum volume he found worked which was 9 1/2 quarts and I had enough flow out of the stand pipe that I knew I was right on the money once it slowed to a dribble and never wasted hardly any oil but it would be totally fine to throw in a full 10 quarts too. I guess personally I wouldn't ruin a perfectly good pan by drilling a hole in it, not with the cost of replacement pans up here or the dorman one anyway with the drain was 500.00 when I priced one out a while back, totally stupid.    I might not have said before but this trans oil type really expands with heat and I think its been said on this forum and the trans shop said the same so I wanted to try and hit the lower temp of the range vs at the top or go shooting above it as that would allow more oil to flow out which wouldn't be ideal.
    • Since I am going to be replacing the pan, I am just going to drill a hole in the original to drain it so I will be able to catch the fluid easier and measure how much I took out.
