HID kit recommendations?
ok, my next question, to all the ddm fans, exactly what setup did you put in your trucks. 35 or 55 watt? slim or standard ballasts? relays or harnesses? Im hoping after this thread, that i can order once and get all the right parts (never happens for me)
thanks again
Definitely run a 2 in/ 2 out harness with a relay ( I think DDM's is only $15) so that it will play nice with the factory low beam wiring; on the fogs you can get away with not running a relay/harness, however, the factory plug for the fog lights is not a standard plug and will not plug into the HID ballast. Because I'm not a wire cutter and want to be able to easily revert to the factory bulbs if I ever need to, I ordered this harness to make the fogs plug n' play: http://www.hidguy.net/Lighting/HID-Bulbs-Components/HID-Harnessing-And-Components/R-Tech-Lighting-5202-H16-9009-Plug-and-Play-HID-Power-Harnessing-Extensions-1-Pair
I'm running 35 watt slim ballast kits on both low beams and fogs. Looks great. If you want the factory'ish look, stay within the 4000k-5000k range.
Could you post a direct pic of them from the side?
here is that shot you asked for. wish i could have washed them first, but its 17 degrees outside, so that just wasnt happening. If you decide to do it, check out some vids on YT first. i taped off the tires, and i think it would have been easier not to. so here you go!
why do you think it would have been easier not to? did the plasti dip not adhere to the tires or something?
Ok, i think i have the setup pretty much ready to order. RAK80, I checked out that link you posted, looks good to me. Im trying to avoid and irreversible changes as well, and im fairly sure im going with the DDMs at this point, most likely will order them later today or tomorrow unless anyone tells me otherwise. Seems to be the winning setup.
For the Plasti-dip questions, im still new to this, and somewhat technologically impaired, but maybe we should start a new thread on this one? Regardless, I did all four wheels and chrome grille surround (generously) with 2 cans, and both bumpers (again, generously) with less than 2 cans. Sometimes (from experience) taping off isnt the way to go, as it will start to peel everything else when it drys. Here is a video i found that is what i ended up doing after the first two wheels, saves alot of time and looks better.
i have ddm 55w, 6k lows, no relay, daytime running lights fuse untouched. no problems whatsoever
how long have you had them in?
For what its worth, I had a DDM Tuning kit and an expesive HID kit from the Retrofit source. Now, keep in mind, my DDM kit was at least 3 years old before it failed but compared to the expensive kit i bought from TRS the DDM kit (to me) seemed to be a higher quality kit. The wiring, connectors, and ballasts just "looked and felt" nicer than the expensive kit from TRS. I sold the car so i wont be able to speak on the longevity of the expensive kit ($160).
I had the DDM tuning kit 3k fogs in my old car for almost 3 years without an issue and then one day one of the lights stopped working. I only paid $60 for the kit back when i bought it so i trashed the whole kit and bought an expensive one from http://www.theretrofitsource.com/ I had the Morimoto Elite kit , 3000k in my fogs in my old car.
I'm actually going to order a spare ballast and one of each bulb just to have on hand in case one quits working....then I can still get my warranty replacement and have a spare all the time.
These guys do an interesting job. They take OEM Japanese projectors and fit them in your standard housing. Nice job on a GMC in the gallery. I'd do it if didn't have to send them my lights for a week. I like the projector look but don't like the halos and LEDs you get with aftermarket stuff.
www.lightwerkz.net
thanks for the posts, It still looks as though the DDM's are everyones favorite. scdean, thanks for the compliment, you should put some pics up of your sierra in your gallery. as for the projectors, you sparked a new interest. I dont know if anyone has ever attempted this on their own or not, but i have seen some with the reflector boxes painted to match the body, and they look good. This is my daily driver though, so i dont know how i would send out the headlights. My only problem with this.
I just put in a 35W ,6K DDM kit in the fogs of my 07 Silverado (NNBS). DDM is shipping directly from China and my package arrived in about 8 days. There are zero instructions with the kits but it was fairly easy to install. I also used a Dremel to grind down the DDM harness pins. I love the color, beam spread and added visibility but have been flashed a few times....wish someone made a projector fog housing that fit in the OEM opening.
Does anyone have recommendations on brands? I bought a "brand x" from eBay and sometimes they work and sometimes they don't. Also having a hard time getting them adjusted. The vehicle is a 2006 Silverado Reg Cab.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
