rpo's am i misssing something?
was going thru my rpo's in the glovebox and 2 of them i looked up that puzzled me were pdf and ppa my tailgate seems to lift just like any other tailgate what makes it so easy? is there something not right? oh and one other that confused me was yd3 user selectible differential? anyone answer my questions?
Sometimes RPO codes mean different things for different product lines.
Example:
G80 is a locking differential in trucks but a limited slip in cars....
PDF could be any of the below:
PDF EZ-Lift Tailgate Package
PDF Security Package
PDF Sound System Plus Package
PDF LT Package 1
PDF CONTROL SALES ITEM NO. 123
PPA is the EZ lift tailgate. You may want to try lifting the tailgate of an equivalent truck without this feature to see the difference.
PPA Tailgate, EZ-Lift
YD3:
YD3 Differential, driver-selectable locking rear
YD3 Differential, driver selectable rear locker
YD3 Front Axle For Scheduling GVW Plate
YD3 AXLE (BASE EQUIP) FOR SCHEDULING GVW PLATE
http://www.gm-trucks.com/rpo-code-lookup/?find=yd3
Example:
PDF LT Package 1
YD3:
http://www.gm-trucks...ookup/?find=yd3
yes i've looked them up already...i dont notice the tailgate any lighter or easier then any other gate i've ever lifted? is there some lifting unit i should be able to see somewhere? and as far as the information that comes up for yd3 ? it doesnt make sense as g80 is the code for rear locker which i have...
YD3 is the code for your front axle, I've only provided you with the factory description. If you google search just those words:
"Front Axle For Scheduling GVW Plate" you can find more info pertaining to it's meaning.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
