2011 belt noise
Have a 2011 GMC 2500HD 6.0 gas with about 2200 miles.I complained about belt noise at about 1600miles and they changed the belt,now at 2200 it is starting to churp when cold but at this point is goes away whem warmed up.Anybody else have this problem? remedys? I would buy a different brand of belt myself if I new that would cure it!
Did they replace the tensioner pulley when they replaced the belt? I had that problem on my last truck and my delaer replaced both, no problem after that.
no they didn't,but it is right on the mark were it is supposed to be
what do you mean about a mark where it should be? I've never noticed any mark on a tensioner pulley. Either you have a mis-alligned pulley, dirt on them or the spring is weak in the tensioner pulley.
If you look at the tensioner there is three marks on the side that doesn't move.then there is a mark on the movable side it is lined up perfectly with the mark in the center.That tells you the belt length is correct as well as the tension.
ok. does the tensioner bounce any when the engine is running? If not, look at the other pulleys and see if any have dirt/grease on them. Is the belt glazed?
Not to butt in here but if your belt isn't bouncing then your tensioner may be shot. Don't get me wrong its not suppose to bounce like crazy but a little with the inconsistancies in the belt/pulleys. I used to get the squeak until warm after I had my truck detailed (one & only time) and found out the tenstioner was bound up and not keeping tension on my belt. I tested it by manually moving the tensioner with engine running. If I loosened it up it would stay loose and if I tightened it stayed tight until next "bump" in belt or pulley then loose again. After I replaced the tensioner, well twice since first replacement was worse, all has been well. I'm still on the factory belt with 91k miles.
I apologize if you knew all this, not trying to insult anyone but that was my experience hope it helps you or anyone else.
I didn't actually check the tensioner myself but I would have to assume that when the tech took the belt off if it was stiff or froze up they would have replaced it? I will check it today just to be sure.
Years back my wife got a low coolant warning on her previous car, sure enough overflow was dry, my bad for not checking it more often. Needed oil change anyway so since dealership is "suppose" to check/top off all fluids I figured two birds, one stone. Well took car in, even had it noted on paperwork that it needed coolant. Next day I go out to make sure the had plenty of wiper juice and .... overflow tank was EMPTY!!!! I cannot repeat here what I said there.
Took it back, reason:
ASE tech:
Since tank level drops as engine heats up, I didn't put coolant in as the engine was warm at the time of service
Lesson Learned:
Trust...but verify
If it was replaced, you could have received a defective part like I did the first go around.
So did you find a fix for your truck?
Not yet,put a gatorback belt on it but is already starting to make a little noise I looked at the pulley alinement last night and everything seems in check! I'm going to look at it some more today,the water pump pulley wobbles a bit but the back side of the belt runs on it and when i spray the backside the noise doesn't quit?
    250.3k
    user087
    user087
  • Who's Online   5 Members, 0 Anonymous, 772 Guests (See full list)
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
