OGM1 with covert medialink install
Here's the connector with wires that connects to the back of the USB/aux jack. The cheapest price found is on Amazon for $88. The connector is ACDelco # PT2278.
http://www.amazon.co...r/dp/B00553Q7J0
Hmmm, looks like a soldering iron's in your future... :)
  • Replies 34
Wow, I'm really confused....can someone clear up what you guys are thinking up for the slow guy over here? :freak:
In a nutshell, I'm ordering the factory USB/aux port module in black, 25832461. I will try to find the four connections per the diagram that Walt showed along with some tweaking to see if I can get it to work. If so, I will solder the 3.5mm wire, 42-3546, to the aux port and connect the 3.5mm terminal to the medialink. I will use the USB A to mini B to connect the USB module to the medialink. If all goes well, that module will be in place of the 12v and 3.5mm passthrough that NCSierra posted in the original post.
Thanks NCSierra!
I don't plan on playing videos from my iPod often but this is the solution I devised to allow me to use it when needed:
My plan for the time being will be to install the new iPod module in one of the following locations:
Upper glove box
Small cubby to the right of the radio
Ashtray
(I don't have the unit yet so I haven't fitted anything up yet)
I bought a USB adaptor that goes from female mini to male-A. This will plug into the male USB mini that comes from, the factory port and from there I bought an extension that is female-A to male-A. This will plug into the new interface module wherever it ends up. This way I will be able to use my factory port 99% of the time to charge my iPhone or to play music from it. If I want to play a movie off the unit, I simply unplug my adaptor plug from the interface module, plug in the video cable and enjoy a movie.
If it works out as I imagine it will, I'll get some photos.
Better check the ashtray size, my ipod did not fit cleanly
The ashtray would just be to hold the interface module- the iPod could be in a cupholder or whatever. Movies are an extremely low priority on my list of objectives so my goal is to maintain a factory-like functionality of the USB port I already have but still be able to watch a movie or whatever if the need/desire arises.
It looks like the black part I received only has an AUX port. No USB. The parts guy is investigating because it looks like the only part GM is making with both the USB and AUX is in white. He agrees that should not be the case.
just wondering....but if its in the glovebox, why does it matter whether or not you have white vs black?
White doesn't look like it came from the factory.
This part is only 3 component so it won't work as-is. I've got a few ideas I'm working on to make it work and will report back when I've got something.
A quick update. I now have the module painted black, wired and ready to install in the upper glove box. I have taken a few pictures of the module and how I ended up wiring it so I will post those when it's complete. I admit it's taking quite a bit of tweaking to get this to work but it should look completely factory when done. The tweaking has involved paint, soldering and judicious use of a dremel and drill.
I wanna see!
the white aux input in the center console of the equinox and camaro looks perfectly factory.
  • NCSierra,
  • OEM 12v outlet – part# 25774623
  • OEM 12v outlet cover – part# 20983936
  • If I understand this right these are the two parts i need to convert the factory usb port to a factory power port useing the taped up cable behind the dash. plug and play?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way to big should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crosing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
    • And overpriced. I was in the Oshawa Truck Plant when they were being built. Very few. I could count on one hand how many I've seen since
