OGM1 with covert medialink install
Here are some links to information and parts that I used to jumper the OGM1 medialink to the factory usb, move it to the upper glovebox, and separately mount a jumpered aux connection that retains ipod video while hiding the medialink pod inside the dash. I spent a lot of time researching options to cleanly mount the medialink, but really wanted my truck to look as stock as possible and I did not care for the look of the medialink pod.
Now my truck stays clean because there are no wires for gps, phone, ipod, etc from the dash. The ipod is hidden and my phone charger is powered from the socket under the center seat.
Here is a pic of the finished product in the upper glovebox. The ipod touch fits perfect lying flat on the left side of the glovebox with just a mm or two to spare. I cut a piece of black drawer liner to fit the bottom of the glovebox to prevent the ipod from moving at all.
Connections in upper glovebox
With jlink cable attached
Here is a list of the parts that I ordered:
  1. OEM 12v outlet – part# 25774623
  2. OEM 12v outlet cover – part# 20983936
  3. Female to female 4-pole connector - http://www.krp.com/4...JACK_p_112.html
  4. Male to male 4-pole 3.5mm cable - http://www.krp.com/4...BLE_p_1017.html
  5. USB adapter to attach factory cable to medialink - http://www.krp.com/U...ALE_p_2230.html
Thanks to Walt, he is a wealth of information:
http://www.gm-trucks...c=131925&st=150
Link to instructions for moving the factory usb:
http://www.gmfullsiz...ad.php?t=219200
***Disclaimer… this setup does work for ipod video and I am satisfied. However, I found that the video will drop out momentarily if I manipulate the aux connection at all while the video is playing. I attribute this to a loose connection, but do not know if the jumper harness, the jlink, or the female to female connector is at fault.
  • Replies 34
Thanks so much for this! You've made my week! Excellent work and write up! I will be getting parts ordered tomorrow!
I found a picture of a factory USB and aux port on a corvette forum. The part number they gave is 20870101. There is also a picture of it. It's a flush mount rectangular module that would look perfect in this location. Did you look at that part?
Here's a link to a thread with pics. It looks like the part may now only be available in white due to a vendor change.
http://forums.corvetteforum.com/c6-corvette-general-discussion/2636199-new-usb-nav-replace-instead-of-pal.html
I think I saw the part you are talking about... similar to this link?
http://www.chevroletmanuals.net/chevrolet-986.html
Did not jump on this part because the aux needs to be a 4-pole (3 stripes on the 3.5mm jack). Since this aux connection is made for audio pass-through, I believe the conductor would be in the wrong position.
Just edited my post and saw yours. What your saying makes sense. I wonder if there's a way to get the proper aux jack fitted in to that adapter. I like that module look better than the round one but I certainly likd the location of yours.
I actually tried spraying that connector with plasti-dip to conceal it better in the glovebox but the application did not come out very clean so I removed it :D
Lol, well either way it definitely looks much better than the media link taped to the dash somewhere! Not to mention a second 12 volt outlet on the dash
Looks like this might be an option if you don't mind soldering. Get the snap in jack and the six foot cable and you can shorten the cable to a few inches to save space behind the glove box.
http://www.minute-man.com/acatalog/4_Conductor_3_5mm_Plugs_and_Jacks.html
or just a black plug:
http://www.markertek.com/Connectors-Adapters/Audio-Connectors/3-5-2-5mm-Mini-Connectors/Calrad-Electronics/30-712.xhtml?30-712-BK
I think I saw the part you are talking about... similar to this link? http://www.chevroletmanuals.net/chevrolet-986.html Did not jump on this part because the aux needs to be a 4-pole (3 stripes on the 3.5mm jack). Since this aux connection is made for audio pass-through, I believe the conductor would be in the wrong position.
After reading a couple of the links above, I took a look at the schematic for the Camaro USB/AUX jack:
It's got a total of five pins in the plug - 1,2,3 & 5 are audio left, audio right, audio ground and AUX detection respectively. Audio outs are straightforward, and AUX detection is just passing a ground signal to the deck to tell it when there's a plug inserted so the deck knows to let you choose "AUX" as a source (100% certain it's connecting pin 3 with pin 5 when the plug's inserted).
What intrigues me is that there are a total of two pins that would not be used in a "hacked" non-GM installation using this plug: pins 4 & 5. Pin 5 "could" be used for video ground (since the audio and video grounds are commoned in the plug anyway), so all we need is to see whether pin 4 corresponds to the fourth ring on the 3.5mm male plug. It almost wouldn't make sense for GM to source a non-standard plug to use in this case (I know - it's GM...), so with a little rewiring on the back side of this factory jack, we could potentially get everything you'd need to make it work.
Great news Walt!
Just got off the phone with my local dealer. He said that item in black is item number 25832461. He can have it it 5-7 days for just under $20.
Great news Walt!
Might be worth it to find out, huh?
Already on order. Worst case, I drill out the aux port and put one of the snap-in 4 pole connectors I referenced earlier.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
