Remote Starter Question
Does anyone know why a remote starter wouldnt work for the first start of the day? I push all the same buttons, the lights blink, and the engine doesnt turn on, though if I go out, start the truck, turn it off immediately, and then try to use the remote starter, it'll fire right up, any suggestions?
Can't say for sure what is causing it to fail. I do know that there are a whole list of things that will cause it not to start right away ranging from low fuel or oil, to most of the computer fault codes. If you dig around on here, there is a list of them somewhere.
I use my remote start everyday in the cold CA winters :jester: and never had an issue. You sure your hitting the lock button first and then the start button immedialy after? Has it always been that way? Try the other remote, it might be the remotes battery. If not take her in.
but it always works, its just the first start after its been sitting there for a while, same key combination, the lights flash and everything. I can walk out to the truck, turn it on, the second it fires up turn in off, get out, and use the remote starter, if it were a low truck battery, that wouldnt work, and if it were the button it still wouldnt start...
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
