Knocking In Engine
Hey all, Kinda new here and have an issue with my pickup. Recently noticed that I have a knocking sound ( sounds like lifters ) on the left side of the engine ( if you have the hood open and faceing the truck ) or right hand side if you sitting inside the truck. What can I do to fix this, if anything? Is it time for a new truck? I first noticed this about 1 month ago. Truck has 63K on it and never been beaten or worked hard. The hardest it's run was bringing my ATV to maine and back.
Descripton: 2005 GMC Sierra 1500 SLT 5.3 Vortec (not flex fuel )
Any suggestions will help.
Thanks
Steve
When you say "Normal LS Noise" do you mean LS as in Trim line? It doesn't seem to do it all the time. The other day I was waiting for someone with my truck running and the noise would come & go. Sounded like a small hammer hitting the aluminum block of the engine.
Thanks again for your response. Just want to make sure im not looking at an engine overhaul in the next few months.
thanks again
Thanks
Steve
Doesn't sound like anything is wrong. Those engines are known to tick. My 2001 Silverado did it from they day I drove it off the dealer lot until I sold it without any issues. Those "LS" Engines are known to be a little loud and have that lifter tick that you are describing.
The noise should go away after about 30 seconds when it starts to warm up. As long as the tick does not stay or progress as you accelerate after the engine temperature is up you don't have an issue.
EDIT : The "LS" engine has nothing to do with the trim level of the truck, it's the model of the engine.
I had a similar sounding lifter noise from my 06 avalanche. At first it was just when I really got on the gas, a month or so later I would here it everytime I accelerated. Luckily I still had a few months left on my powertrain warranty. Took it to the dealer and they first said stuck lifter. When they broke it down cam was shot, multiple lobes were chipped and not hitting lifters smoothly creating the noise. They replaced the cam and all lifters. According to the dealer it was bad metal in the cam which caused the failure and they had seen it a couple of other times. Forgot to mention mine had around 80000 miles. Hope it is not your situation, just wanted to give you a heads up! I think the service ticket was around $1600 (can't remember for sure, covered by powertrain warranty). Good luck with yours.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
