  • Replies 36
I used to get the 3M tint but now I get Solar Gard. It's a little less and holds up just as well. I think next time I'm going to do 5% in the back and keep doing the 20% up front.
The shop I go to uses Solar Guard. I've had it on 4 of my vehicles and I'm happy with it.
You know what, I just looked and yesterday when I took my girls '11 Malibu in, I had them go with Solar Guard. My truck I know has 3M tho.
Yep the Solar Guard has held up for me and has a lifetime warranty I think. Nothing better than tinting all side and rear windows. Stock tint is not dark enough and tinting the front only will not match the rear perfectly. It doesn't cost much more to do them all. I guess if money is tight only do the 2 front sides but it doesn't look as good to me. But to each their own.
They used lumar? Or something is that good stuff
Never heard of it but that doesn't mean it isn't decent stuff.
I've heard of it and seen it, but I have never used it or know anyone that has. I have no idea on the quality either, could be crappy, could be good.
I agree that the factory tint isn't dark enough, and sometimes it's hard to match it. So, I just put 5% over everything...and it matches pretty good cause it's solid black. :lol:
Can you get away with 5% on the front in IL?
I was able to get away with it where I lived when I was 16, almost 8 years ago, but I can't anymore. :tear:
Legally, no...not even close. I think 35% is the max on front windows. However, I live in a small town, and the cops don't really worry about it. Plus, I drive country roads to work every day, so I don't see cops all that much. Maybe it's a small town thing....but, so far, so good! :fingersx:
That's awesome! That's how I got away with it back in the day. Now, even the small town inspection shops will not pass me if it's not legal. :nonod: I have even pulled up with thew windows down just hoping, and they will roll them up to check them.
Totally illegal to have the front windows tinted in Michigan so when I have my front's done, I'll have them done to match or just a shade lighter that way I don't have Jonny Law pulling me over all over town.
I had Llumar installed on my G35. It's a top tier film that's metallic based and not pigment based. By metallic, I don't mean the mirror reflective junk. Supposedly the metallic based films hold their tint longer. I've had the car for 8 years and not noticed any problems. When I tinted my last truck (done at the same place), they told me that the pigment based film will match the factory tint better, so I told them to do that. I didn't have any problems with that either (had the truck for 7 years) so I'm not sure it really matters all that much. I don't recall what brand film that was.
i have my rear window 5% on top of the stock, and my front doors are stock matched and its a perfect match.. would of liked 5 all around but the staties give people shit for it around me
That's a bummer dude. We don't have to get our trucks inspected here in IL.
We don't have to get our's inspected here in Michigan either but if a cop pulls you over, they can ticket the hell out of you for having the side front windows tinted on any vehicle in this great State of Michigan. Sucks.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
    • I had an alternator fail that was shorted internally in such a direct fashion in addition to the larger gauge cables that it appeared like a VERY dead battery. Granted I think the car did power up, it definitely wouldn't start.   Rodent damage to wiring?
    • ... I don't think he could.
    • Using experience to justify bad advice is lazy and typical of someone incapable of articulating why their advice is prudent.    This immediately sets off the BS alert and the advice that followed certainly qualified.   Asking an idiot for help getting out of dumb situations because he is an expert... at getting himself into dumb situations.   Unless I've been living in an alternate universe - the first thing everyone does when getting into a sticky situation is shift to a higher gear 🤨.   Of course not, the torque multiplication, mechanical advantage and finer control typically afforded by the lower gear is far better suited for this scenario.   There ARE scenarios where a higher gear MIGHT be appropriate determined more by the drivers ability to control EXCESSIVE wheel spin versus applying torque to the ground.
    • I'm not sure I agree with "extreme" low speed, high torque sentiment here with regards to the prescribed use of low range. How about...whenever it's needed?   A 2.72:1 transfer case and whatever differential gears these Silverados have (3.42's, maybe?) aren't producing "extremely" low crawl speeds. Or insanely high torque multiplication. Even with the 1st gear in these newer transmissions. But it does provide mechanical advantage and potentially better control at slower speeds. And with extra weight or towing, I think it adds mechanical sympathy for the truck as well.   Plus, traction control and the other assists generally turn off when you shift into low range. Those aren't needed here, they'll work against you if you need wheel spin. In high range you'll need to figure out how to turn off the various modes those assists provide. Depending on the vehicle, those things don't all automatically turn off or turn completely off.   While I agree that a farmer might have some great practical experience, a recommendation to "always" using one gear isn't very informed advice. If the farmer had said WHY and could explain the physics behind his prescriptive "always" I'd definitely listen. The way he's described here makes it sounds like he could either be uninformed or is telling everyone what worked for him, not necessarily that there could be a more advantageous way about things.
