Oil pressure dropping off
Itsme7
I definitely was getting ahead of myself. The drop in pressure was just a bad sign to me, since i know oil pressure is vital to the engine, and with the problems ive had in the past with the truck with a blown trans and other stuff going, i was at my witts ends with the truck lol. Today i went to move the truck, start the truck and the pressure gauge moved slowly until 10 psi or so then shot up to 40, then dropped down to 35-30 within a second or 2, so i turned the truck off. Put the key in the ON position, and the gauge was reading 5 psi or so? started the truck and did the same thing as before. Turned the truck off and put it in the on position again, and it was registering 10-15psi with the engine off? pretty sure my gauge or sending unit is shot lol. So im getting a modular pillar with a mechanical oil pressure and coolant temp gauges. Sigh of relief lol.
you would know if your oil pressure was way way low....i'm sure the engne would sound like a couple of robots laying pipe in a laundry mat
have you had cluster replaced by GM? '05 was one of the model years that had screwy cluster stepper motors. I'll still put money on sending unit or stepper motor
Nope havent had it replaced, dont really want to mess around with it, would rather install a mechanical gauge and call it done lol. If i install a gauge, wont i have to disconnect the current one which would make the DIC freak out on me for low oil pressure?
True. Is there anything i can T into for a oil pressure pickup?
T into the stock oil pressure sending unit. Get a Y fitting that fits the engine and put the stock sending unit on one side, and the mechanical tube on the other side.
If the stock gauge is still reading something with the key in your hand, then the problem is in the dash, not the sending unit.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
