70k miles and RC level
My buddy just got a 2008 silverado and wants to do a 2" RC level like me. Should any precaution be taken since the truck has 70k miles on it? I don't know how much things would have settled/worn into position and if the level would suddenly create an forced wear and tear
Provided the truck was properly taken care of your buddy should be fine. I installed mine right around 70k miles myself. Just make sure the truck gets an alignment when done.
like said above, if the balljoints are on their way out it will bring it to attention sooner, but ive done trucks with well over 100k on it, just do it he'll be happy he did
we done it on my dad 2009 sierra only thing is we striped one of the sway bar link loosing it, no big deal just replace it and its all good
    President Roberto
    President Roberto
  • Who's Online   4 Members, 0 Anonymous, 1,042 Guests (See full list)
